Question about Kenmore 98702 Stacked Washer/Dryer
MY KENMORE STACK WASHER DRYER MODEL 110.80754001 IS BLOWING AIR BUT WON'T HEAT UP
MODEL 110.80754001 WILL NOT HEAT UP WHEN TRYING TO DRY CLOTHES
  • 1294 Answers
SOURCE: Kenmore Model # 417.90812990 Stack washer & Dryer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose (behind machine) should be approx 3 feet from ground level when you are re-fitting.
Rate me pl.....if helped.
Posted on Jan 03, 2008
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
  • 1122 Answers
SOURCE: kenmore model 417 94702300 stack washer dryer wont
bad lid switch-mike
Posted on Jul 30, 2009
Joe Onley
  • 363 Answers
SOURCE: Kenmore Washer Model#23922200 does not spin
I assume this is an older top loader. You may have something stuck in the pump itself. I can tell you how to check this. Following is cabinet removal instructions:
  • Using a Phillips screwdriver, remove the screw from each side of the console.
  • Pull the console forward and up to remove the tabs on the bottom of the end caps, out of the holes in the top.
  • Lift the console up and lay it on its back.
  • Unplug the harness connectorfor the lid switch.
  • Insert a flat screwdriver into the front edge of the clip (located on both sides), and pry back. Remove both clips from the holes in the cabinet and slide down the other end of the clips and out the slot in the rear panel.
  • Open and hold the lid while grabbing the cabinet front opening. Be sure when tilting the cabinet that the back edge clears the vacuum break.
  • Tilt the top of the cabinet toward you by pulling on the lid and opening of the cabinet. This releases the back slots of the cabinet from the tabs in the back of the base.
  • Carefully pull the cabinet away from the base of the washer and set it aside.
    Now you have access to most of the parts.
Now in front of you on bottom is the pump. It's usually white in color. Without taking it off the motor, make sure it is someplace where you can let the water run out of the machine. Remove the clamp from the wash tub to the pump and look inside. There may be a small garment or something similar inside. You can use a small needle nose plier to get to this and remove it. Reattach the hose and close the cabinet in reverse order.
Hope this helps you
Joe
Posted on Aug 30, 2009
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Auto dry not working on stack washer/dryer
If your dryer isn't drying, check for a simple fix first. Make sure the dryer is set on a high heat setting, empty the lint filter, and reduce the size of the load by taking out some items.
Also, check to make sure the clothes are not dripping when you put them in the dryer and make sure a dryer sheet is not blocking the vent.
It could also be a problem with your dryer not being level or the vent hose is clogged. For more tips and solutions, check out these troubleshooting steps in Dryer not drying.
Sep 12, 2012 | Kenmore 98702 Stacked Washer/Dryer
My kenmore elite model 70094990 will not heat or dry clothes. blowing just air.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 19, 2011 | Kenmore 63942 Dryer
My dryer doesn't completely dry my clothes. Usually I have to run almost 2 cycles to get my clothes dry.
check your vents,, inside the house and outside,, check to make sure the vent hose is not kinked,, if all is good make sure the unit is blowing out air good, if so then you may have a thermostat or heating element going out,,, i have seen alot of vents on the outside get wet and clog up
Jan 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
Jun 02, 2009 | Kenmore Dryers
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
75 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
