Question about Brother IntelliFax-2820 Laser Fax
Warming up message
Machine stops with "warming up" message and will not send or receive. Any solution. "warming up" is not in the glossary. The machine is definitely warm since it is left on all the time.
How long have you had this machine?
Posted on Jul 28, 2007
  • Sean Helmi Jul 28, 2007
    how long have you had this machine?
'Unfortunately 'Messages has stopped' how can I get it going again
for the same reason as the other ones, you did turn it on wifi calls..
in order to send and receive text message you need to turn it off.
settings/wifi/more.
at the bottom says wifi calls you need to disable then try to send a text message.
Feb 04, 2015 | Cell Phones
Fax machine is able to receive faxes, but not able to send them. There is a "No Response" message every time I try to send a document.
Hi, i think your fax machine works fine, A "no response" message indicates that the receiver should accept your fax by hitting on the start button (normally its a green button) for you to able to send a fax or if no one in your friends location is receiving it. In this case you might as well set your fax machine to auto receive fax, defends on your fax machine's model. i hope this helps.
Aug 04, 2011 | Office Equipment & Supplies
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
How do i change outgoing answer phone message
Solution for Fax1360, if this does not work please let me know as this process should be the same.
Recording an outgoing message (OGM) on an external TAD 7
Timing is important in recording this message. The message sets up the ways to handle both manual and automatic fax reception.
a Record 5 seconds of silence at the beginning of your message. (This allows your machine time to listen for the fax CNG tones of automatic transmissions before they stop.)
b Limit your speaking to 20 seconds.
c End your 20-second message by giving your Fax Receive Code for people sending manual faxes. For example: 'After the beep, leave a message or send a fax by pressing *5 1 and Start.'
Recommendation: recommend beginning your OGM with an initial 5-second silence because the machine cannot hear fax tones over a resonant or loud voice. You may try omitting this pause, but if your machine has trouble receiving, then you must rerecord the OGM to include it.
Christy
Sep 26, 2010 | Brother Inkjet Fax Machine Fax1460 Plain...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Icon identification on text messages inbox
it means the message saved to your SIM card, not your phone.
May 06, 2009 | Samsung Gravity SGH-T459 Cell Phone
Incomming sms is not received in nokia 6030
Hi
there are only settings on the phone that will stop sending of messages, settings will not stop the receiving of messages (unless their mms - picture messages). I would suggest you speak to your network as it maybe something on your account at their end that needs fixing?
Incoming mesages (sms) are directed at your mobile number so the phone will receive them as you do a call.
Let us know how you get on?
Apr 22, 2009 | Nokia 6030 Cellular Phone
FAX MACHINE WILL ONLY RECEIVE MESSAGES THAN SEND THEM
You can't make it just receive.
Unplug the power cord for 10 seconds.
Nov 10, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
229 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
