Question about Amana Dryers
My dryer won't turn
My dryer motor burned out. I would like some detailed instructions on the disassembly of the dryer to replace the motor and any other related parts.
  • 1 more comment
  • Toney Bartholomew
    Toney Bartholomew Nov 12, 2012
    Model# NED7200TW Amana Electric Dryer...
  • Richard Roth
    Richard Roth Nov 12, 2012
    Here is the motor you need to order.http://click.linksynergy.com/fs-bin/clic... To replace the motor remove the front panel of the unit to gain access. Let me look thru my database to see if I have the service manual for that model. If I don't, I will post a manual for a similar model. The process will be the same regardless.
  • Richard Roth
    Richard Roth Nov 13, 2012
    OK, I don't have a service manual but here is a video to show you how to access the inside of a dryer. Please let me know if this helps you or if you need any other information. If you should need to contact me immediately, please go tohttp://appliancecafe.com and use the contact form link from the top of the page. This will alert me instantly to your request. Please be sure that you have the unit unplugged before attempting to replace the motor!
    Top Expert:
  • Amana Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
  • Toney Bartholomew
    It's an Amana NED7200TW. Sorry for the delay response. Thanks
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Kenmore 70 Series Dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 19, 2011
  • 239 Answers
SOURCE: Maytag performa dryer model #PYET344AYW wont stay running
Yes, I suspect the motor is at fault. The motor you need is available below!
Motor <----- CLICK HERE FOR THE CORRECT PART FOR YOUR MODEL
Posted on Aug 23, 2012
Testimonial: "Thank you for your help! I think we are just going to get a new dryer..reading about the Whirlpool model WED4900XW...thoughts on that? There are mixed reviews!"
Sears laundry center 92702 burning smell and won't drain spin out
If the motor is running and it won't drain or spin, then the motor coupler has failed and needs replacing. Here is a link to the part.
Here is a video to show you how to replace the coupler. If you could post the model number that is located on the unit I can get you the service manual to help you a little better.
Oct 18, 2012 | Sears 24 in. Electric Laundry Center with...
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
My LG Dryer DLE2301W won't turn on.
you need to get new dryer/ you got short circuit on the motor
Aug 27, 2012 | LG Dryers
Dryer not powering/turning on
Investigate these areas if your dryer is not starting: Proper Voltage from the House Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in. Door Switch If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it. Start Switch A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again. Thermal Fuse A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it. Thermostat A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective. Timer Motor Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly. Motor A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor. For more info see the following link: http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Aug 05, 2012 | LG DLG2532 Gas Dryer
Motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Jan 19, 2012 | Whirlpool Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
heatman101
Aug 11, 2011 | Dryers
Maytag gas dryer
This is valid for a Maytag Neptune MDG3000AWW Gas Dryer (I am responding to a problem which was mis-identified as a MDG5500AW Gas Dryer)
NOTE: Motor problems begin intermittantly. They can be temporarilly fixed by blowing out the motor with compressed air. Eventually ALL motors fail. In my case, with six kids it took 10 years for our Maytag motor to fail. YMMV.
  1. Confirm where the burn smell is coming from. This will require you to disassemble the dryer. This is not hard - it will require the following tools:
    crosstip medium screwdriver
    1/4 inch socket
    5/15 inch socket
  2. UNPLUG DRYER
  3. TURN OFF GAS
  4. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  5. This has exposed the interior.
  6. IF your motor still made sounds when pressing the start button, THEN plug the dryer back in and have an assistant press and hold the start button. You press the dryer close door button (on front panel which you set aside) and observe and listen. IF the glow plug in the gas ignition chamber glows bright, it is fine. You may see a slight curl of smoke or smell some smoke from the glow plug. THIS IS NORMAL and indicates your ignition circuit is fine.
    Observe the motor. Listen and smell. IF you see smoke from the motor, or IF you hear a "starting sound" but the motor itself doesn't spin, is very slow to start spinning, or makes racket, or it made a noise and then stopped... THEN your motor is burned out. Confirm by sniffing the motor. IF the motor smells burned, THEN your motor is burned out.
  7. IF you determined your motor has burned out, THEN you can replace the motor for around $100. OR you can replace your dryer for > $700. Your choice. It is slightly tricky getting the motor out. Instructions Below.
    NOTE: If your motor is burned out it CANNOT be fixed because it is a "double wound motor." The motor must be replaced.
MOTOR REMOVAL INSTRUCTIONS
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Expose the dryer interior by following instructions above
  4. With the drum out do the following:
  5. Remove the blower cover by unscrewing the 8 screws
  6. Remove the cotter clip securing the front of the blower to the motor spindle (Try using two screwdrivers... You'll need to replace this cotter clip because it will deform)
  7. Remove the wiring harness on the back of the motor
  8. Remove the two motor securing clips holding the motor to the motor support frame (this is tricky - I got them off by leaning on the top of the clip with a heavy screwdriver and a large channel-loc wrench)
  9. Remove the cotter clip between the motor and the blower housing
  10. Remove the two 5/16 inch bolts securing the motor support frame from the motor
  11. Lift out the motor and blower housing
  12. Have an assistant support the plastic blower barrel tines with the motor hanging down and the blower up
  13. Using a hammer and a punch tap the motor spindle (axel) until the blower is free of the motor
  14. Take this motor to your appliance repair center for replacement.
To replace simply reverse these instructions. GOOD LUCK!
Sep 14, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
43 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
