Question about Sewing Machines
Juki model lu-2210-6 bobbin drive disengaging
I raise the machine to inspect it and the spring loaded mechanism that is supposed to be engaged on the drive end of the machine will keep kicking out of place so the dogs and the bobbin hook assembly does not work.what could cause this
  • 155 Answers
SOURCE: Installing the hook and bobbin assembly.
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this  good luck  thanks.
Posted on Oct 26, 2008
  • 27 Answers
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
Posted on Jan 10, 2009
  • 6 Answers
SOURCE: Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Posted on Mar 12, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
  • 3741 Answers
SOURCE: I have a Juki Lu-562. The safety clutch counter
click this link directly .http://www.raichert.com/adobe/LU562%20LU563.pdf ------ its mentioned on page number 12 of the link.ablout the clutch spring adjustment. --------- check out.keep updated.thanks.
Posted on Nov 10, 2009
Have a juki tension top and bottom loose,top tension mechanism tight what do i do?
Remove the thread from the machine. ALWAYS RAISE the presser foot and re-thread from the beginning. Verify that the thread follows the correct path. Set the upper tension to the midway point between high & low number.
Re-install the bobbin (make sure it turns the correct direction in the bobbin case). Thread the bobbin thread through the bobbin tension.
Test your machine.
Dec 14, 2016 | Juki Sewing Machines
The Bobbin Assembly will turn in reverse but not forward Juki LU-563
Most likely the bobbin retainer has been bent. Turn it over by hand with the power off and look carefully, you will prolly see it.
Dec 18, 2014 | Juki Sewing Machines
After winding a bobbin on my Juki TS2010Q and releasing the winding lever, my machine will not run, Up/Down needle or cut. The electronic buzz indicates that it is trying but nothing happens.
Have you tried pulling gently on the thread coming up from the bobbin? If this doesn't give, the thread may be tangled around the mechanism (under the machine, where the bobbin fits). Open that section and you should see if there is excess thread wound around. Clear this, and when you put the machine back in place, gently hold the bobbin thread to assist in not having loose thread to tangle again. This sounds like my machine sounds when that happens to mine so I hope this fixes it.
Jan 20, 2014 | Juki Sewing Machines
I need a manual for Juki LU-1508 sewing machine. Can any one help?
contact a juki dealer about a manual
email these sites about a manual
sewingpartsonline.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
sewingmachines.com
May 17, 2012 | Juki Sewing Machines
Juki dnu-1514s The machine is threaded and and the bobbin is loaded. When I sew, the machine does not make any stitches. It's as if the machine is not threaded and I'm just running fabric...
Your bobbin system isn't engaged. this can happen for several reasons, mostly when things are a little out of whack.
The 1541 has a 'clutch' it located near center on the bottom surface and is a silver circle below the 'arm'. Bring the needle all the way down, now push the clutch and hold while you turn the wheel back (top away from you) eventually the clutch will click when everythings aligned and engage the bobbin system again.
Jul 14, 2011 | Juki DNU-1541 Mechanical Sewing Machine
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
I have a Juki LU-562 sewing machine I was sewing thick leather it made this clunk noise and a spring flew out of it underneth it now the hook just turns and it doesn't sew.
Like most of the older sewing machines, the lu-562 is usually an easy fix when it comes to issues of timing and even broken parts. First determine where the spring came from and that should point you to the parts that need replacing and/or readjusting. But, by all means DO NOT continue operating the machine until its fixed. Without actually seeing the machine, it sounds as if the needle bar spring failed.
Sep 28, 2009 | Juki Sewing Machines
I have a juki industrial machine when i try to fill bobbin the machine just carries on normal sewing the wheel to fill bobbin just dosent move
so many different versions to disengage the drive, but all are located on the right hand side of the machine on the part that allows you to rotate the sewing mechanism by hand. there is likely a button or that part will pull outwards
Aug 16, 2009 | Juki HZL-E61 Computerized Sewing Machine
Bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
May 31, 2008 | White Sewing 2999 Mechanical Sewing...
Looking for a manual
JUKI HOME SEWING DIVISION 8500 NW 17 th Street Miami, FL 33126 Phone: (305) 594-0059 ingrid@juki.com she will send you one
Mar 25, 2008 | Yamata FY700 Mechanical Sewing Machine
Sewing Machines Logo
66 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
