Question about Teac Nostalgia GF-680 3-Disc CD Changer
Lens is not reading cd in player - Teac Nostalgia GF-680 3-Disc CD Changer
    Master:
  • 689 Answers
Look for a different one,It will cost you more to have it repaired, With the labour rates now a days,
Posted on Nov 09, 2012
5 Suggested Answers
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
localwonder
  • 6784 Answers
SOURCE: Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Posted on Sep 14, 2009
Warf135
  • 137 Answers
SOURCE: why does Burn't Audio CD not play on some CD Players
This problem is not due to codecs, as all audio cd's and cd players use the same format (with the exception of CD players that have MP3 capability).
The problem here is due to the Quality of the blank media being used and also the laser unit in the stereo. Some stereos will not play copied or burned discs at all.
You can try burning the cd at a lower speed as sometimes this creates a more stable burn and will work. Also try branded (high quality) discs. if all this fails then you have to be resigned to the fact that unfortunately the Yamaha won't play burned discs and thats that.
Posted on Oct 18, 2010
My dvd player ejects the cd when i load it
Either the reading head on the laser is dirty or bad and it is not recognizing the CD. If it is a homemade CD there might be a formatting problem that is not compatible with your player
Apr 17, 2011 | Televison & Video
Tip
How to repair CD Player not reading
I need help please CD Player lens is not reading how to cure this How to clean the lens I tried with TDK Lens cleaner CD
on Apr 06, 2014 | Sony CMT-CP505MD CD Shelf System
Won't play cd all I get is troc read
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Take care.
Apr 13, 2011 | Emerson MS3100 3-Disc CD Changer
I have a CD player problem does not play any CD's Thanks
Good luck.
Mar 08, 2011 | JVC XL-MC222BK CD Player
MY SHARP CD PLAYER WON'T READ CD'S AND SAYS NO DISC.
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say no disc.
Good luck.
Feb 22, 2011 | Sharp Audio Players & Recorders
Not read disk No lee los discos No reconoce los
Take care
Sep 02, 2010 | Denon DCM-370 5-Disc CD Changer
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
IT POWERS UP FINE BUT IT DOESNT SEEM TO BE READING THE CD'S I PUT IN EVEN ONES IT HAS READ IN THE PAST.
the lens cud be dirty or damaged or the cd spindle motor has gone bad. in case of dirty lens try using lens cleaner cd. that dont work means probably spindle motor is out.
Mar 12, 2010 | Nu Mark Numark Cdn36 Dual CD Player CD...
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
Spins CD but displays"read " but plays nothing
Hi, this is CD lens assembly failure. the len sits in a lens assembly that has a motor that allows it to travel along a rail. this is how it reads the CD in motion. this assembly has failed and , you will need to replace this mechanism in order for the lens to be able to read once more.
May 17, 2009 | Numark MP-102 CD Player
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
