Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Kodak 5300 aio change inks
Printer says colour ink needs changing, but when i lift up lid to replace ink the cartridges are to the far right where you cannot get to them.The instructions on how to change them seem to say when you lift up lid you should have access to them all. I have is a blue screen telling me about the ink, a flashing red light, and the on/of switch alight but nothing seems to work thanks.
  • j_c_s Jan 08, 2009
    have tried this but ink cartridges still move to far right so I new that the cartridges moved when turned on, so turned on printer and yanked out power cord when cartridges appeared,changed them, works ok.
When you turn the printer off and back on you should hear a noise, when you lift the lid the cartridges moving to the center so you can replace them.
Posted on Jan 06, 2009
Kodak 5300 printer: I just changed the black ink but it is printing as though there is no black ink. Ihave tries calabrating, cleaning, deep cleaning, etc. It says there is a full cartridge of ink.
From what i understand with the kyocera colour printers theres a menu option to print black as black opposed to a combination of the colours. I'm not too sure where it is, however it sounds like the kodak is very simular and is using the colours to create black instead of using the blank ink cartrage.
Jun 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need to replace ink cartridges and the printhead
Lift the door then unplug.
Slide your fingers under the cartridge carrier and check for paper debris or other obstructions. If none are found try sliding the cartridges out gently to the middle then replug and see if this resets it. If that doesn't cure the problem unplug again and move the cartridges to the opposite side of the bar as far as it will go then replug.
Now close the lid and wait for a self check. If nothing happens you may have a broken belt.
Mar 07, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just replaced Printhead on my AiO 5300
from what i know, kodak already released an imkproved and upgraded version of their printhead so i guess you dont need to worry about that anymore.
Oct 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black inkwon't print
pictures are not clear even after installing new ink cartridge and cleaning print head
Oct 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5300 will not accept the new ink cartridges
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
63 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
