Question about Panasonic KX-TG1033S Cordless Phone
My phone are not charging is it the battre - Panasonic KX-TG1033S Cordless Phone
  • Panasonic Master
  • 14,641 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 09, 2012
My phone was working fine, I put it to charge the next day I realized was not charged
probably your fone batt is extrem low. you need to find 5volt dc source to "recharge" your batt to the minimum state so you can recharge it again using your daily charger.
Sep 23, 2015 | ZTE Boost Max Black Boost Mobile
Batt won't charge
Please check the charger if it can charge other similar phone. Also check if connector is ok.
Jul 19, 2012 | Android Apps
My nokia 5200 has a battery charging problem.it shows its charging but the battery is still low when i remove from charging.and it gets switched off
Once i had the same problem like yours. I thought that my charger or my handphone were the problem. I borrow my friends batt, then i put it in my nokia, then it was working!! it means the problem is in my batt. I went to the service center, then they said my batt is broken. i tried to find another sources afterwards, then they said the same. I had no choice, i should buy new one. uufftt!!!
May 10, 2011 | Nokia 5200 Cellular Phone
I cant charge my phone. I've taken it in to the store before with this same problem, and they told me if the prongs inside the phone are bent then it wont take a charge. it's happened again, how do i...
hi im josh in cebu phils. may i help you friend? As an experience mobile technician i say that it is just simple friend don't worry. Friend try to open your back casing remove the battery underneath or behind the battery you will see the 4 or two metal terminals connected to your battery you just bent that exactly that it will touch the battery prong. be sure that all terminals will touch the prong of the battery when you installed the batt. because it  is were the  current passes so that it can enter your batt. and if it is not contact or attached it cannot enter your batt thats why not charging will occur.so be sure that terminals  will contact or attach the batt prong. so that your problem will be solve.  good luck friend hope i help you.
Mar 13, 2009 | Motorola Mobility W375 Cellular Phone
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
Razor will not charge
my own razor does this also. the problem is the charging port on the phone. try using an electronics cleaner inside the port but do not oervsaturate. Otherwise if the phone is warrantied or you have insurance take your phone in and get it changed. I had a spare phone that i use to charge my battery. hope this helps.
Sep 11, 2008 | Motorola Mobility RAZR V3
Low batt problem
put it into the water
May 15, 2008 | Nokia N70 Cellular Phone
Phone won't start
Did you turn the phone off before removing the battery? I sure hope so. If not, you may have to junk it. My father has done that to several phones now. He pops the battery out to put the charged on in, but forgot to turn the phone off. I just recently bought him a phone that sets itself to power off when the battery cover is popped off.
Dec 23, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
No charge
check the batt mayb your batt drained off... try using other batt.  if still doesnt work, probably you have a software or hardware failure...
but if it works w/ other batt try charging it, if still doesnt charge your phone charging section have a prob...
just visit your nearest service center to help you...
Oct 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Panasonic KX-TG1033S Cordless Phone Logo
109 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
