Question about Epson 4880 Stylus Pro InkJet Printer
4880 carriage noise
What could be wrong if, upon starting the printer, a loud grinding noise originating from the carriage mechanism occurs ? and the message is to call "service "... Print head ? Carriage transport? Gears ? Can I attempt to fix such myself ? Thank you ?
  • Lionel Delevingne Dec 19, 2012
    Head is totally locked up... cable, at least the soft one I see looks fine...
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Posted on Apr 23, 2006
Basti
  • 1447 Answers
SOURCE: R200 jammed carriage Grinding belt
Hi-
Normally it will not allow you to move carriage manually. Belt is broke. have it service or purchased a new one.
Hope this helps
Posted on Nov 08, 2008
jacklee366
  • 541 Answers
SOURCE: Epson R320 "General Error" message - unable to clear
try downloading the ssc this will reset your printer
Posted on Mar 03, 2009
tbreeze47
  • 3083 Answers
SOURCE: Printer: Epson Stylus Photo
This sounds like a gear problem. There is a large plastic gear that drives a couple smaller gears to feed the paper, as it prints. The printer will have to be disassembled and the gear inspected for damage- it sounds like a tooth or two are bad, which would explain the problem occuring later in the paper feed.
You can take it into a Computer repair shop to see what they think, but I would contact Epson just to see if they can offer you a better solution.
Even if you discovered a bad gear yourself, the part can be hard to order, and you often have to go through an authorized dealer, just to get a part.
Often it's better to just get a new printer due to the cost of repair.
Here's Epson's support site:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Good luck, and hope this helps.
Posted on Dec 12, 2010
Grinding noise Dell 5110cn
Grinding noise usually is a mechanical issue with printer. It could be because of any obstruction in the carriage mechanism or the gears.
If your printer is In-Warranty ( within 12 months from the day you purchased it ), then you should be calling Dell for Free Replacement.
If your printer is Out of Warranty, I still suggest you call Dell as they may offer you a better deal for your printer.
Regards,
Suhail
May 16, 2012 | Dell 5110cn Laser Printer
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Print heads go to left grind
The carriage sensor (usually a photocell arrangement) that senses the carriage position when at the end probably has dirt or has failed. It usually is a couple of small black fingers that a "vane" on the carriage goes between. If the vane is broken or the sensor broken the carriage will keep trying to move farther as it cues up. Once it has cued up itself, it counts pulses to the drive motor to keep track of where it is.
Sep 08, 2009 | Cannon Canon i960 Photo Printer
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Nov 19, 2007 | HP Color LaserJet 2600n Printer
Epson 4880 Stylus Pro InkJet Printer Logo
70 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
