Question about Sewing Machines
Juki model lu-2210-6 bobbin drive disengaging
4 Suggested Answers
  • 109 Answers
SOURCE: I need a manual for a JUKI LU 563
JUST check at google ,com manuals
and then write you model# or you can go directly to your manufactury on line or if you heve costumer service # call them
Posted on Aug 15, 2009
SOURCE: How do I change the stitch length in my Juki LU
hi there
the graduation of the stitch length is marked on the feed graduation plate attached t the main shaft,to adjust the stitch length rotate the hand wheel slowly as you keep pressing the push - button stop the bed until the tip of the push- button enter groove of the accentric mechanism, when it is entered rotate the hand wheel eigher towards you or away from you as you keep pressing the push - button until the desired stitch length indicating mark on the graduation plate appears on the hole of arm. when appear release the push - button and check stitch length.
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
Posted on Jun 22, 2011
bargainbox
  • 1388 Answers
SOURCE: instructions
try sewusa
Posted on Nov 10, 2011
My Juki LU-563 stopped picking up the bobbin thread, changed needle, took out bobbincase to look for thread, none, still won't sew because of bobbin thread not being picked up.
If you've properly installed a brand new needle that is correct for the machine, threaded it correctly, checked that the bobbin is installed correctly and the bobbin tension threaded properly, most likely the machine is out of time. In other words, the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin. (You can open the bobbin area, hand rotate the handwheel and watch how and where the needle moves in relation to the bobbin to see where and why it is not connecting.) You can search the internet for web sites and videos that discuss machine timing or you can take it for service.
Nov 09, 2016 | Juki Sewing Machines
Timing on the Juki LU-1508H
HI THERE
please see attached for how to adjust timing between needle and hook.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Feb 18, 2015 | Juki Sewing Machines
The Bobbin Assembly will turn in reverse but not forward Juki LU-563
Most likely the bobbin retainer has been bent. Turn it over by hand with the power off and look carefully, you will prolly see it.
Dec 18, 2014 | Juki Sewing Machines
Can't get Juki tension right
which tension is wrong
if thread is bunching up under material increase the tension of the needle thread if the bottom thread is loose then increase the bobbin thread tension
each thread result for above or below material will indicate which thread to alter the tension on
Jul 02, 2014 | Juki Sewing Machines
After winding a bobbin on my Juki TS2010Q and releasing the winding lever, my machine will not run, Up/Down needle or cut. The electronic buzz indicates that it is trying but nothing happens.
Have you tried pulling gently on the thread coming up from the bobbin? If this doesn't give, the thread may be tangled around the mechanism (under the machine, where the bobbin fits). Open that section and you should see if there is excess thread wound around. Clear this, and when you put the machine back in place, gently hold the bobbin thread to assist in not having loose thread to tangle again. This sounds like my machine sounds when that happens to mine so I hope this fixes it.
Jan 20, 2014 | Juki Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
I need a manual for Juki LU-1508 sewing machine. Can any one help?
contact a juki dealer about a manual
email these sites about a manual
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
sewingmachines.com
May 17, 2012 | Juki Sewing Machines
I just received my Juki 8700. I new to industrial machines. How do I wind the thread onto the bobbin?
There should be a bobbin winding device next too and slighlty behind the drive belt.
Should be like this bobbin winder.
Mar 11, 2011 | Juki DDL-8700
I have a juki industrial machine when i try to fill bobbin the machine just carries on normal sewing the wheel to fill bobbin just dosent move
so many different versions to disengage the drive, but all are located on the right hand side of the machine on the part that allows you to rotate the sewing mechanism by hand. there is likely a button or that part will pull outwards
Aug 16, 2009 | Juki HZL-E61 Computerized Sewing Machine
Looking for a manual
JUKI HOME SEWING DIVISION 8500 NW 17 th Street Miami, FL 33126 Phone: (305) 594-0059 ingrid@juki.com she will send you one
Mar 25, 2008 | Yamata FY700 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
