Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Blue and black vertical lines over the picture
Blue and black vertical lines running through the picture. This problem with the picture is on all video inputs... What do you think the problem is???
The TV is a Sony Grand Wega KDF-55WF655
  • wgmurray Jan 08, 2009
    I contacted Sony on the 5th - I asked about the extended warranty on the optical block and I was told it expired 12/31/08 (5 days after my problem). I called a few repair shops to get a quote on the replacing of the optical block - 900.00 to 1400.00. My TV is only a little over three years... I can't believe the cost to repair considering I can buy a new TV for 1500 - 2000... I own multiple SONY TV's and have never had them in the repair shop...I thought SONY made a good product - What type of big screen should I look at buying to replace the old one???
    Novelist:
    Scholar:
  • 67 Answers
This problem is most likely related to the Optical BLock of the TV. There is a board, called the C board, that does all of the thinking for the optics of the television, and there are tests that can be run to confirm this.
Try pressing the MENU button (or WEGA GATE, HOME) on the remote control. If the menu that pops up has the same lines running through it, then it is definitely the Optical Block. If not, that doesn't rule it out completely. You can try Sony customer support, and they should be able to run you through some tests to confirm the exact cause of the problem.
Hope this helps you...
Posted on Jan 05, 2009
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
My Samsung LN32D403E4D has vertical blue lines flashing in picture, why?
It sounds to be a T'Con broad problem. Check all the flat cable connections in between lcd pane and T'Con board for firmness. Re-seat them once and check. If you wish to get more details about these kind of faults to Samsung LCD model TVs, check this site.
Feb 06, 2013 | Samsung Ln32d403e4d
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
NO PICTURE BLACK SCREEN AND A BLUE LINE ACROSS SCREEN.
The vertical circuit has failed. This can be as simple as poor connections on the pins of the vertical IC or a defective IC. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide details and instructions.
Dan
Apr 01, 2009 | RCA TruFlat 27F520T 27" TV
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
204 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
