Question about Maytag Refrigerators
Ice maker works- but water and ice will not dispense through the door
The lights on the door are on, did the 3 second trick to unlock & reset the water filter. Neither the OK or the change light is on ( on the door). It made plenty of ice-so the water is getting there.
  • Sue Syrek Nov 11, 2012
    Thank you everyone for trying to help. We did many of these things. My husband noticed the solenoid switch when he took the front panel off. He figured it out. We thought you pushed the button to dispense-- DUH not push the glass against the back of the dispensing area. How dumb we feel. But thank you for your great suggestions.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
4 Suggested Answers
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
  • 7 Answers
SOURCE: Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Posted on May 15, 2009
  • 135 Answers
SOURCE: ice maker wont fill.water dispenser on door is working
Could be the filter. Can you bypass the filter? How about the incoming water line. Is there presure there?
Posted on Aug 26, 2009
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
I have a whirlpool side by side.water and ice in door,water runs normal but no ice.
Ken, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Jun 28, 2017 | Whirlpool Refrigerators
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool(Model: GS6NBEXRL01) Side-by-Side has a sensor on the right side of the freezer and a flap on the left. The light is red and the icemaker is making ice, but will not dispense through the...
The Dispenser Lock (on some models)
ice and water dispensers. To turn off the ice maker, see "Ice
Maker & Storage Bin."
• Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
• Press and hold LOCKOUT a second time to unlock the
dispenser.
Let me know if this is your problem, Can get the manual for you if you like, Sea Breeze
Feb 04, 2009 | Refrigerators
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
44 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
