Question about Lenovo G530 Notebook
My pointer is stuck and I can't get it to move!
  • TandT Development Co. Nov 09, 2012
    I found the problem! Someone had hit the switch in the upper right hand corner that stops the cursor from moving- gee what an easy fix that was.
  • Lenovo Master
  • 7,627 Answers
Reboot if you haven't tried.
Posted on Nov 09, 2012
5 Suggested Answers
nothnagel
  • 20 Answers
SOURCE: Whenever I type in a document the cursor jumps to
This may be a software or driver conflict. Look for out-of-date apps. Look for version numbers of all apps, games, utilities. Belarc (free at belarc.com) is a simple tool to gather all the version information on your computer. Confirm that each program's "system requirements" list your current OS level by visiting the software manufacturer's site and checking for your specific software or driver version. Either remove or update any that are not specifically compatible.
Posted on Oct 21, 2009
  • 12 Answers
SOURCE: "OS missing "problem lenovo 3000 g530 :
Its two-way: either you have a bad hard disk or your PC is infected with virus. Check your anti-virus if updated. Run a disk diagnostics if your hard disk has no bad sectors.
Posted on Dec 07, 2009
ruwidperd372
  • 279 Answers
SOURCE: My Lenovo G530 laptop does not acept sound drivers
On Win XP , you need to install Microsoft UAA before installing sound driver. Get the right drivers according to your operating system.
http://www-307.ibm.com/pc/support/site.wss/CONS-SUPPRT.html
Posted on Apr 10, 2010
SOURCE: cursor(pointer) cannot be moved by using touchpad but possibe wit
To stop the mouse jumping around whilst you are typing, have you tried configuring the touchpad? I had the same probelm but found configuring the touchpad to "disable whilst typing" then settng the "reactivation time" to one second.. This seemed to solve the problem in my case. I have a Medion Akoya. Good luck, Brian
Posted on Jun 07, 2012
Hp 630 touchpad not working -pointer moves but doesn't click
Double click on pad surface. Buttons could be faulty. Check mousepad settings. Install drivers
Dec 08, 2012 | HP Pavilion ZD8110US Notebook
The cursor jumps around on my ASUS K501J notebook.
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 08, 2012 | ASUS K50IJ Notebook
Moved pointer intermatic T104
The time pointer is supposed to be stationary.
On T104 timer the pointer is stationary pointed downward at 6:00 position. So you can move it so it is pointed straight down and add a bit of super glue where pointer meets stem.
Copy following link for instructions how to set T104 timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 05, 2012 | Intermatic T104 24h 208-277v Mechanical...
Sticky mouse eachine had win xp installed win 7 pointer still stuck
You need a new mouse. Upgrading an OS will not fix a hardware problem.
Jun 27, 2012 | E-Machines Computers & Internet
Yamaha P-250 Stage Piano won't boot up...
Yamaha pianos go through a self test on start up. This could indicate a problem on the main motherboard.
Try a hard reset.
Hold down top C key while turning on.
Wait for it to start up, if it still freezes its time to take it to the repair shop.
Mar 27, 2012 | Music
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
Gas guage not working. been told it is fuel sensor
{: ) A faulty fuel level sensor is most likely. But you must rule out first if theres' any problem with the gauge itself, like a stuck needle. A scan tool can command the cluster gauge to move at full sweep, effectively ruling out problem with the gauge. Without scan tool you can only approximate your judgement, like when you turn on your igniton, did the pointer move from fully down up to the Empty scale? Or did the needle never ever moved even a little?
Aug 04, 2010 | 2006 Chevrolet Trailblazer
Toshiba Satellite Laptop Pointer stuck
GO INTO CONTROL PANAL MOUSE OPTION TAP KEY WILL HIGHLIGHT THE BOX YOU ARE IN MOVE IT TO REFESH UPLOAD NEW DRIVES BECAUSE THE OLD ONE CORRUPTED SOME HOW , RESTART MACHINE
CANDYMANGANDY
Jan 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Lenovo G530 Notebook Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
