Question about Linksys Cisco Wga600n Dual-band Wireless-n Gaming Adapter
WGA600n firmware is corrput, no wireless light on setup, wont recognize adapter
My win 7 os cannot recognized the crusb10075 3com adapter.
1. Don't plug your WLAN USB adapter until setup finish and reset the computer
2. Download XP driver from 3COM in below link... make sure to select the correct one depending on the serial number of your adapter (starting with 0100/0200/0300)
http://www.wireless-driver.com/3com-officeconnect-wireless-54mbps-11g-compact-usb-adapter/
3. Double click and it will automatically unzip and may ask you again after unzip use recommend settings and click yes to use recommend settings and click yes to all to overwrite again the folder unzipped again but if didn't ask it is OK.
4. In the unzipped folder right click on the setup file and click properties then go to Compatibility tab. InCompatibility mode click "Run program in compatibility mode of" then chose Windows XP (Service Pack 2) and OK.
5. Click setup now and after installation finish restart your computer.
6. After reset plug you USB adapter and will take some time to install the driver.
Apr 20, 2011 | 3Com (3CRUSB10075) 802.11g/b Wireless...
When i install the drivers for TP-Link WN353GD adapter, I already get a warning that it may not be compatible with my system. Currently i am running Win XP SP 2. Is there sometime i can do to overcome...
Update your Wireless Adapter firmware @ http://www.tp-link.com/support/download.asp?a=1&m=TL%2DWR340GD
There are 3 versions for your product(TP-LINK TL-WN353GD, Important***select the correct firmware version to update. Then download the latest drivers(Setup Utility) & and install the drivers for your adapter from the TP Link site.
Link - How to look over the hardware version on a TP-Link device?
Hope it helps.
Apr 05, 2011 | TP-LINK TL-WN353GD 802.11g/b Wireless...
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
I was given a dual band gaming adaptor model wga600n but i don't have the installation cd for it how can i set this up without the cd
SEARCH COMPLETE PRODUCT NAME / INFO TO THE INTERNET AND DOWNLOAD THE SOFTWARE DRIVER.
WHEN DOWNLOAD FINNISH DOUBLE CLICK THE FILE AND RUN.
Dec 25, 2010 | Linksys by Cisco WGA600N DualBand...
Belkin F7D4101 v1 Play Wireless USB Adapter: Plug it in, no green indication lights, no response from the Adapter at all. Computer doesn't recognize that the Adapter is even plugged in.
Hi, Belkin adapter need to be configuration also with the same at your router or ISP provider so your connection will be an range.
The first think you need to know if what is your Wireless security mode WPA/WEP64bit or 128 and what is the channel of your signal.
Depend of the windows operating system one big solution is a setup windows cero configuration manually without use any software . is you cant resolved it contact me for a remote your pc for a manual configuration.
Oct 29, 2010 | Belkin Play Wireless USB Adapter (F7D4101)
Ive recently changed the password on my wireless network and now my printer keeps flashing orange which means it wont connect to the wireless. From reading a similar post i saw you recommeded to reset the...
To reset the printer's wireless network adapter:
  1. Press Setup(wrench icon).
  2. Go to Network Setup, press OK.
  3. Go to Reset Network Adapter, press OK.
WiFi light will temporarily turn off then will turn on solid orange. Now, run the printer's Wireless Setup Utility on your computer to configure the printer with the new wireless settings. You will need the USB cable temporarily to successfully configure the printer. Thank you for choosing Lexmark.
Sep 10, 2010 | Lexmark X4650 InkJet Printer
Computer doesn't recognize device
remove previous all drivers for this device and install again, if not works , setup your OS freshly.
Sep 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Will not install
You mean the adapter is not recognized by your computer or the setip CD is the one that is not being read by your computer?
If the adapter is the one that is not being recognize by your computer try connecting it on another USB port on your pc and if still not detected by your PC try connecting that adapter on another computer's USB port just to check if it will be detected by your pc, if not retirn the device back to store.
But if you're saying that the setup CD is the one that is not being recognize by your PC try downloading the software from the manufacturers web site.
Hope it helps..........
Jun 16, 2008 | NetGear MA111 802.11b Wireless Adapter
How to connect my ps3
No. You must use a wireless game adapter for your PS3. If your PS3 do not have the built in wireless adapter you can try the Linksys WGA600N
Mar 12, 2008 | Sony Playstation 3 (PS3) Console
Linksys Cisco Wga600n Dual-band Wireless-n Gaming Adapter Logo
93 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
