Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
My soap won't dissolve during the cycle.
I am using a fdb750rcb frigidaire. The soap I am using is cascade action packs. When I run a cycle everything functions normally as far as I know except when I open the door to the washer, the soap packet is unused. The door to soap dispenser is open but the soap is unused. I have used three different packets all with the same result. At first I thought it was maybe old soap but I put the soap in a cup of water and it dissolved in less then a minute. Any help you would be able to provide would be greatly appreciated.
Thank you
  • sthawk Jan 06, 2009
    I also have the problem with the soap not dissolving. I tried using liquid soap and it to was just dumped onto the plates below and hardened. If i use a packet soap I find it at the bottom of my dishwasher in one piece still...
  • Anonymous Mar 30, 2014
    soap not dissolving
  • 50 Answers
You are not getting enough water or you are losing the water during wash cycle. Is you dishwasher new or older? How is it plumbed in? If it is plumbed through the floor you will have to put and air gap in to keep the water in it. All tall tub dishwasher have to be plumbed properly.
Posted on Feb 26, 2009
Make sure that your utensils are not keeping the door from opening. just a bread knife in the bin leaning out can get between the detergent door and the trays.
Posted on Apr 15, 2009
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
There is a white film on everything at the end of the cycle
check your soft water conditioner for low salt or no operation,as you need soft water for CLEAR non streaked glasses
Jan 14, 2011 | Maytag Dishwasher
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
We use the Cascade tablets but they don't dissolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 13, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
Aug 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Soap won't dissolve in dishwasher
I had the same problem and my wife fived it by unsticking a valve to the left side of machine in front lets water in she poped it open and dried soapm came out restarted and now works fine.
Jul 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher tablet not dissolving during any wash cycle
check the four things
1. run faucet to increase temp going to machine.
2.add jet dry liquid in compartment. fill then shut door and lower then raise the door,3times this will take the air out of the dispenser compaRTMENT. then refill somemore repeat steps until nomore can go in.
3. add the soap cascade is good. after that start the machine and thank me with a 4 thumbs up post. thanks!
Jun 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Detergent packs are not dissolving
Either:
Good luck,
Vlad
Apr 21, 2009 | KitchenAid 24 in. KUDS02SRSS Stainless...
Soap problems
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some (quite some) water at least once, if not - check water valve, water level float and water pressure.
Good luck,
Vlad
Oct 21, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
3,172 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
