Question about Tomtom ONE GPS Receiver
TomTom ONE V1 (4N00.001) wont boot
Hi, hope you can help,
My TT ONE V1 wont boot correctly. When I press the on pushbutton it displays the logo screen, then the white screen with the TT on it. Then the loading bar gets to about 80% then the animation of athe SD card coming out of the TT with a red X over it.
Its not the SD card - I've tried 4, all 2GB or under.
If I have Navcore 7 or 8 on it I can see the display in HOME but not on the TT unit itself.
I have tried resetting - and I've now put the latest firmware onto it.
Very occasionally it does load fully - then it displays the splash.bmp file and then hangs with that displayed.
Tried the clearflash routine.
Tried clean card and installing from HOME
Tried other peoples TT dumps.
Tried disconnecting battery.
Think thats it - any ideas?
Thanks in advance
5 Suggested Answers
  • 68 Answers
SOURCE: The antitheft.bmp on my TomTom One does not
Make sure the picture is *exactly* the right size. For a wide-screen TomTom, that's 480x272 pixels.
Posted on Jan 15, 2010
SOURCE: TomTom One 2nd edition - Please help!
I had exact same issue today! I had to put the SD card into a card reader and in another USB port on my PC and then I formatted the SD card and then copied a previous TomTom backup onto the card. Worked fine after that. For some reason when it was in the TomTom it kept reporting there was only a few mb left when there was at least 100mb left.
The catch is to backup!
Posted on Nov 09, 2007
  • 3 Answers
SOURCE: TomTom go 700 flashing cross at start up
U need just one original file from zour tomtom and that is ttgo.bif so keep that file safe and copy everything from working unit (even better with patched system) to your unit, !!!!! dont use TomTom Home !!!! just through drive (if its not there cant help), just possible that u need now maps activated for your unit, u can find info how to this anywhere,
Posted on Feb 05, 2009
SOURCE: tomtom one (4N00.012) will not load up.
Your particular unit runs it's software from SD-Card. you need to check if the card is not damaged: while unpowered push the SD card to come out insert it in a card reader on your computer and see if it reads it ok, if it ask's you to format it it means it's damaged and should be replaced ( the sd card of your tomtom should be replaced with another SD card which you should buy from tomtom for your particular device not a generic one). if it reads just fine reinsert it and start the device again..And about the reset the correct procedure is: Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.904537f.gif
You should also install Tomtom Home on your computer, connect the device and update it if al the above failed (with a verified and working SD card inserted) - link for Tomtom Home: Windows, Mac
Posted on May 30, 2010
christykraj
  • 107 Answers
SOURCE: hi, I have tom tom
Please follow the steps below to solve the issue. This is caused by an update. If you are not sure, how to do this, call TomTom help line for assistance.
STEP 1 - Find the mapsettings.cfg
- Connect your device to the computer and switch it on
- On your PC, click on My Computer to access your TomTom drive. On a Mac you can double click on it on your desktop
- Inside the TomTom drive, you will see a list of folders (on Windows these are yellow, on a Mac they are blue) as well as some loose files
- Please find the folder that is named as the map on your device i.e. United_Kingdom_and_Republic_of_Ireland_or_Western_Europe etc
- Double click on this folder to access it and please find the file called mapsettings.cfg
- Please delete this file
STEP 2 - Creating a manual backup of your map
- Right click on this folder and copy it
- Go to the desktop of your computer and paste the map folder
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your map.
STEP 3 - Format your TomTom device
IMPORTANT: ONLY continue if you were successful in making the back up of your device
For PC users:
- Open My Computer. Right click on the TomTom device drive and click 'Format'. Make sure Quick Format is not selected.
For Mac users:
- From the Finder menu, click 'Go' > 'Utilities', then double click 'Disk Utility'. In the 'Disk Utility', select the volume below the TomTom disk. Make sure the 'Format' is set to 'MS-DOS (FAT)' and click 'Erase'.
STEP 4 - Remove old files from your computer
- Open TomTom HOME
- Click on 'Manage my device'
- Click on the 'Items on computer' tab
- Tick the options for 'Applications' and 'Voices'
- Click on 'Remove items from computer'
STEP 5 - Install the software on your device
- Click on 'Update my device'
- Tick the options for 'Application' and at least one voice (eg, Jane)
- Please do NOT select your map at this stage.
- Click on 'Update and Install'
- Click 'Done'
Your navigation device starts and then connects to the computer again. HOME may offer more than one application update. Please repeat this step until no further application updates are offered.
STEP 6 - Restore the map
- Find the map you copied to your desktop and copy it again
- On your computer go to 'Start' -> 'My Computer' and open the TomTom drive
- Right click anywhere and select 'Paste'
STEP 7 - Check the Device
- Eject the drive (on Windows, go back to My Computer and right click on it and select Eject; on a Mac, drag the drive into the trash)
- Please disconnect your device and let it load up as normal
- You should now be able to set up the device as normal
Good Luck!
Posted on Jun 14, 2011
My tomtom has a red X and a disk in the corner. It will not let me exit out. I have tried reseting but nothing. What could I do
1. open your tomtom as a folder 2. copy all info from tt to a new folder on your computer 3. format tt in fat32 4. download tomtom home and run it 5. make all upgrades that the tthome sais 6. copy the folders with maps and voices from saved ones 7. if restarts or freeze on logo, open tt as folder and delete the file MapSettings.cfg from map folder 8. say thank you
Apr 26, 2011 | Tomtom One XL GPS Receiver
When turns on shows a computer screen and red cross
Go to TomTom Home reconnect and then go to device on the tool bar. Select disconnect device and this should free up your device and take the red X off.
Goodluck,
Please don't forget to rate my solution
Apr 26, 2008 | Tomtom ONE GPS Receiver
My tomtom is free it turn off by itself and screen goes up and down showing to choose language only. can't go to the navigation applicatio ? Help please
Tom tom is stuck on start up
Apr 22, 2011 | Tomtom One XL GPS Receiver
Tomtom go 4V00.710. Green light is on when charging but tomtom will not turn on.
i had the same problem; there is a simple reset solution, which is not described in either of the manuals which i have.
This involves removing the SD card, pressing a (tiny) reset button for 15 seconds, pressing the on/off switch for 5 seconds, then replacing the SD card. To locate the reset button, try the TOMTOM website/Support
Sep 01, 2009 | Tomtom GO 720 GPS Receiver
Tomtom wont come on
More than likely the negative post on your 910 is not making a contact. This is a known problem for the X10 series tt's. It can be fixed but you have to disassemble the tt to do it. No just replacing the battery won't fix your problem. If it was just a battery problem your tt would still boot up if connected to external power.
Jun 12, 2009 | Tomtom GO 910 GPS Receiver
The Logo screen freezes on start up.
Connect it to your pc then turn it on. It should either connect or ask you to connect to the pc. If tt home opens shut it down. Do a complete backup of your unit onto the desktop. DO NOT USE TOMTOM HOME TO DO THIS!!!! After doing a complete backup format the drive on your tt useing fat 32. Open tt home and let it reload your os. Do this a couple of times to get the newest os. Disconnect your tt from the computer the way you normally do and restart your tt. Reconnect your tt and do not let home start. Go to your backup and copy and paste your maps back onto the root of your tt. If you have any question email me.
Hope this helps
May 07, 2009 | Tomtom GO 920 GPS Receiver
Tomtom Go 710 - help
The answer is Yes. I would make sure to have a backup on your PC. Uninstall TT home make sure you delet all of it. Reformat your card then install TT home. Connect your tt and let TT home reinstall your navcore. You may need to reconnect your tt a couple of times to get it updated to the newest navcore for your device. I believe it is 7.903. If you want to keep the older navcore just don't load the new one. Then install your maps as you normally would. I have just used this method to get the latest navcore for six 710's.
Hope this answers your question
Nov 15, 2008 | Tomtom ONE GPS Receiver
SD card for TT one XL
Card needs to formatted using fat32 in windows formatting options, then copy and paste your back-up files one by one to your new card.
Hope this helps
Oct 16, 2008 | Tomtom One XL GPS Receiver
My tomtom wont boot
Do a reset. Most tt have a reset hole in the bottom (to see where the reset is for your device visit TomTom. If your device does not have a reset hole press the on/off button for at least 15 seconds. If this does not do the trick and have not played with operating system you probably have a burned rectifier (not worth fixing).
Jun 30, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
3,464 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
