How many gallons of propane will I use per month?
How many gallons of propane will this Carrier furnace use a month? I have the option of getting a free Carrier furnace and installing it in my home which is currently using oil for heating. I would like to know if installing this furnace would be worth it. It boils down to how many gallons of PROPANE this furnace will burn a month and how much that would cost. I know I will need to buy the conversion kit as it is set up for natural gas.I need to figure this out to know if i will be saving money by switching to propane from oil. I could use 125 gallons of oil per month. If I estimate the average price at $3.60/ gal. I could easily spend $450/mo for oil. The current price for propane per gallon is $2.99 as of today. If anyone can help me figure this out based on the furnace's specs and this info about my home it would be greatly appreciated! The specs on this unit are as follows.. Carrier model # 58PAV111-16 Input BTU/HR: 110,000 Output BTU/HR 89,000 House specs... 2100 sq.ft Newer Windows insulation is moderate
    Master:
  • Heating & Co... Master
  • 523 Answers
The furnace manufacturer specs is 89,000 btu/hr. Compare that to the btu's/hr on your existing oil burning furnace. If the oil furnace is 89 or 90,000 btu then the Carrier is sized about the same as the oil burner you have. It will operate at about the same btu's/hr. so that tells me you will save money in the long run. I know this don't answer your initial question but energy consumption (both fuel and electric), is calculated by a load on the house, which has many different variables. Hope this helps!
Posted on Mar 06, 2017
  • 3,238 Answers
Go on to google and use BTU per gallon calculator at Irving energy this will give you the price between them both
burzerko
  • 254 Answers
SOURCE: Natural Gas to Propane
Hello
Yes you will need to buy the orifice to convertit to propane.
After you install the orifice, you will need to also adjust the manifold pressure with a monometer. And you will also need to put the stickers on the gas valve that will state that this unit has been converted for use with propane. If you have any other questions feel free to comment back.
Thanks
Posted on Jun 03, 2008
  • 182 Answers
SOURCE: I want to be prepared
not only do you need the nozzles....you will need the spring changed in the gas valve and a manometer to set the proper gas pressure output from the valve.If you change the jets only you could do alot of damage to your furnace.
Posted on Sep 23, 2008
  • 96 Answers
SOURCE: extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Posted on Jan 25, 2009
  • 142 Answers
SOURCE: Jenn Air cooktop JGD8130ADS - Propane to Natural Gas
propane has more BTU, so has a small hole, NG has a laeger hole, when i last called a plumber, all he did was remove them and drill a larger hole...i don't know what the hole size was, but thats what he did. hope this helps
Posted on Jan 31, 2009
  • 10865 Answers
SOURCE: dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
Posted on May 27, 2009
I recently installed a new furnace ..with a Riello 40 series burner models f3 how many litres Of fuel should I be burning pr hour ..
The Riello 40 Series F3 Burner has a firing range from .50 Gallons per hour to .95 gallons per hour. The burner is adjusted by the tech for the proper BTU input.
Mar 09, 2018 | Heating & Cooling
CARRIER 58RAV NG GAS VALVE SPRING
Try national energy they are on line and sell spares for converting nat gas etc
Mar 26, 2017 | Carrier Grilling
I have a new Hayward H400FD ! How much Propane does it need in one hour of heating ??
A 100k btus burns roughly 1 gallon of propane per hour. A400k btu heater burns approximately 4 gallons (actual is somewhere between 4 - 4.18 gallons per hour.) That's assuming that the heateris running non stop during this time period.
I know your question was fairly simple and disp notrequire a whole lot of information but we appreciate you giving us somefeedback!
The Ugly Pool Guy
www.WeFixUglyPools.com
Dec 11, 2010 | Hayward H Series Pool & Spa Heater 400k...
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
What color should the flame be on a coleman
hi the gas goes along aburner tube then comes out of the burner then it hits a baffle in side the heat exchanger as long as there is not sooting the flame will look yellow , i would say the best thing would be to contact the makers of the furnace direct they should have a technical department , they might be able to offer more help or have there own people to look at the heater most of these companys have a warrenty on there heaters
Jan 09, 2010 | Coleman Propane Forced Air Heater...
Can i hook two 500 gallon propane tanks together instead of purchasing a 1000 gallon tank?
yes you can but please get a propane gas certified engineer to do it , its really a job to be done by experts , the explosive power of propane is just to dangerous to mess with
Nov 10, 2009 | All-Pro Propane Garage Shop Heaters - All...
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
I want to be prepared to change my Carrier Furnace from Natural Gas to Propane if I need to.. I was told that their should be a little sack with a replacement jet hanging there somewhere. There is not.. ...
Sep 23, 2008 | Carrier Heating & Cooling
Propane consumption
1/3rd of a gallon per hour on high. It will not run on high all the time. .3X24=7.2 gallons worst case.
Sep 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Inefficient (big, yellow flame) on wall propane heater, using up propane too fast
A clue to what could be wrong is that you mentioned it took 10 minutes for the pilot to go out. It could be your gas valve. Get a technician in to check your gas pressure both before the gas valve and after. Have them check it as the water heater is running.
May 15, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
