Question about Whirlpool DU943PWK - Multiple Color Built-in Dishwasher
We have a Whirlpool DU943PWKT0 dishwasher which continues to blow the 'thermal fuse' periodically.
I have a previous post about this unit where a solution, i.e. replace thermal fuse fixed the situation. Now some 3/4 weeks later the unit has stopped again and it appears it is the thermal fuse again. We've used this unit in the same location for over a year now and 'why' would this unit begin to toast thermal fuses, given this is the current problem. I will follow up after finding time to inspect the unit again, but I'll bet it is the fuse again as the unit is stone cold dead in mid cycle as last time with the bottom standing full of water. It appears to go kaput during the rinse cycle... Thanks
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
rickzilla
  • 706 Answers
SOURCE: Dishwasher will not drain
Hello Tom,
Glad that you were able to find something out of place in the check valve ( like the gasket) which in turn was restricting the ball in that check valve from being in the right position. I'd be willing to bet that your problem is solved..
Regards,
Rick
Posted on Dec 08, 2008
  • 530 Answers
SOURCE: dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Posted on Jan 04, 2009
wheelshot
  • 102 Answers
SOURCE: Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Posted on Apr 04, 2009
  • 11 Answers
SOURCE: My Whirlpool GU2400XTP dishwasher keeps blowing
Are you replacing the wires along with the fuse? It is important to change the wires too as they are usually the cause for the fuse blowing. Be sure and get the fuse kit that includes the wires.
Is your water too hot? Hot water is fine but too hot of water can cause the fuse to blow over time. The temp should be somewhere around 120 F. Anything over 130 F is way too hot. I personally don't use a long high steam final rinse or high heat because over time the steam and cause the electronics to short as steam and moisture can get into the keyboard and inside panel.
Posted on Apr 08, 2010
Whirlpool Point Voyager Dishwasher blows thermal fuse - pump motor draws 10A
Yes 10amp seems a lot of current being drawn by the pump motor. Not sure if it is safe to run dishwasher in this condition. One reason could be a leaky capacitor on the motor. Try to replace it. See item 26 on http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU1500XTLB0/1198/0130000/W0503069/00008
Apr 04, 2014 | Whirlpool Dishwashers
Why thermal fuse is blown
If you have no power to your machine and the power is on it is the thermal fuse. If the fuse is blown you will get no power at all. To my understanding after talking to many people the thermal fuse is likely the first thing to go bad on a whirlpool dishwasher. A power surge to your unit would cause the fuse to blow or the control board to go bad.
Jan 13, 2013 | Whirlpool 24 in. DU1100XTPS Built-in...
Nothing will start and no lights are on and water won't drain from bottom on dishwasher.
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a Whirlpool
dishwasher model #DU1055XTPS you appear to have a concern with no lights/power to the control, correct ?
The one thing I'd suggest is the thermal fuse, typically the symptom you've described is associated with a bad thermal fuse. (part #
W10258275).
Here's a helpful link below to a video from "repairclinic.com" to assist in changing (or simply checking it as shown in the second link) the fuse kit...it generalizes on most Whirlpool built dishwasher's such as yours, but if slightly different it is essentially the same.
http://www.youtube.com/user/RepairClinic#p/search/0/jdlVbTXm8SY
http://www.repairclinic.com/PartDetail/Thermal-Fuse/675813/679723
I'll watch for your reply and try and help going forward. Hopefully this will provide you with the solution you seek, but please keep me posted if not.
...If so, please take a moment to rate the assistance provided for you here today. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Oct 17, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
No power to the control panel
dishwasher model #DU1100XTP you appear to have a concern with no power to the control, correct ?
W10258275).
Regards,
Macmarkus :)
Oct 13, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
I have a Whirlpool Quiet Partner 3. It sat up for a few months because the control panel went out and it took a while to save up and order a new one. Now it blew the thermal fuse. I put a 15amp...
A 15amp automotive fuse is rated for a 12VDC system in an automobile, not a 125VAC houshold electrical system in an appliance. I don't think your automotive fuse can handle the start current being drawn by the main wash pump as the dishwasher starts. I would recommend you replace the thermal fuse in the dishwasher with an appropriate replacement BEFORE assuming you have a problem with anything else in the dishwasher.
Some Whirlppol manufactured dishwashers had a noted problem with the thermal fuse. The gauge wire used in the control panel would heat up and cause the thermal fuse to blow prematurely. The manufacture's answer was to provide a replacement kit that you were to splice in place that had a larger gauge wire. The thermal fuse replacement kit for Whirlpool dishwashers can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The thermal fuse should be listed under the "Control Panel" parts listing. The average cost is usually about $15 or less.
If you have questions, please post back with your MODEL NUMBER and let me know.
Aug 12, 2010 | Dishwashers
Whirlpool DU1055XTSS dishwasher is totally dead as if it were unplugged. No response from front lights. Only 3 years old. Another post for an different Whirlpool model says it's the thermal fuse, but I...
If you have power going to the dishwasher, meaning the breaker, switches, wiring and fuses in the home are okay, the most common cause for your symptoms is the thermal fuse.
The thermal fuse is a small disk shaped device that is behind the control panel on the right side it is snapped on to the electronic module. The part number for your model is W10258275
Jul 24, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
I have a kenmore elite dishwasher model#665. no power
Nearly all Kenmore dishwashers have a thermal fuse inside the operator console. If the fuse blows, it will exhibit the symptoms you describe. If you post back with a COMPLETE model number (located around the tub opening with the door open), I can verify, provide you with a part number, and explain to steps required to replace it.
NOTE: "665" is the manufacturer code, which identifies the manufacturer of your dishwasher as Whirlpool.
Nov 18, 2009 | Kitchen Ranges
Power to dishwasher but no power to panel
Open your console and check the continuity of the thermal fuse (clipped to the electronic control unit [ECU]).
Post your model number if you're still having problems and I'll try to assist you further.
Apr 04, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
WHIRLPOOL QUITE PARTNER ii
there is a thermal fuse attached to the main control, check for continuity if none replace fuse.
Jul 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU943PWK - Multiple Color Built-in Dishwasher Logo
64 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
