Question about Tecumseh 5hp Engine Snow King Mtd Blowers Lh195sp67517
Tecumseh 5hp feul bowl leaking
The seal is leaking
  • 430 Answers
Tecumseh rebuild kit number 63021B comes with a needle and seat, bowl gasket and bowl nut gasket. Should solve your problem.
Posted on Nov 12, 2012
A/C compressor front seal leaks 134a. Can the can of 134a with leak sealer really seal the leak?
No, the stop leak is designed to seal a leaky O-Ring. I have never seen anything fix a compressor seal other than replacement.
May 17, 2016 | 1997 Ford Expedition
Bellhousing leak
did you just have the fluid replaced in the transfer case?? if the answer is no, the you may have a leak from the series of seals that are internal. you will have to have the transfer case removed and have the CVT seal replaced and other seals inside of the transfer case. lengthy repair and costly also. the transfer case has to be removed to replace the CVT side seal and while you are in there replace seals inside of the transfer case also. that what its sounds like to me. transfer case seal leak or the inside CVT seal leak. however if its leaking right from the bellhousing, it also could be the torque converter seal. this is when proper diagnosis comes to play. if its d converter seal, than the trans has to come out. have this one checked by someone that knows what they are doing. could be transfer case seal leak and it could be converter leak.
Jul 12, 2013 | 2003 Nissan Murano
Oil leaking trans 1999 chevy S10 replaced torque converter seal leaks at front
ou may need to remove the front pump and replace the seal on the pump and the converter seal as well
Aug 08, 2012 | Cars & Trucks
The Dodge Dealer is saying the crank seal and cam seal are leaking when they went to change the oil, are these transmission seals or engine seals? do I need to place them or is there a product that will...
Crank seal could either be at the front or rear of the engine (there are two) Cam seal is at the front of the cylinder head. If the leaks are minor, a good product that may help is lucas conditioner and sealer. Larger leaks require an actual seal replacement. No sealer will work immediately. The reason most leak is because over time the seal hardens from heat. It takes a while to soften it up again.
If the leak is from the rear main seal, the transmission needs to be removed to get to it but neither seal is part of the transmission.
May 21, 2011 | 2000 Dodge Caravan
Leaky transmission fluid. possible reasons?
TRANSMISSION LEAKS COME FROM TRANSMISSION OIL PAN GASKET LEAKING.OIL COOLERS LINES LEAKING.LEAKING AT TORQUE CONVERTER FRONT SEAL.TRANSMISSION SPEED SENSOR SEAL LEAKING.FRONT AXLE SEALS LEAKING AND LEAKING AT TRANSMISSION COOLING LINES TO RADIATOR.CHECK ALL YOU WILL FIND LEAK.IF YOU HAVE FAST LEAK OR PRESSURE LEAK.WITH CAR RUNNING IN PARK EMERGENCY BRAKE APPLIED LOOK UNDER CAR IF YOU SEE FLUID LEAKING OUT IN LARGE QUANITIES.COOLER LINES LEAKING OR TORQUE CONVERTER FRONT SEAL LEAKING.IF YOU HAVE SLOW LEAK THE LEAKS HAS TO BE AXLES SEALS OR PAN GASKET LEAKING OR VSS SENSOR SEAL LEAKING.
Aug 03, 2010 | 1998 Pontiac Bonneville
Oil leak -between inner primary and transmission . Changed broken belt and now I have this leak. I put new mainshaft seal and jackshaft seal. Help!!!
There are several seals that can leak in this area. You say you replaced the mainshaft seal in the back of the primary. I've seen a lot of people replace this seal only to have it start leaking immediately. The reason was that they didn't know you must lubricate the seal before you reinstall the primary cover. When you put the primary cover on with the seal dry, when the engine starts up, the mainshaft immediately goes to 1000 RPM or higher with no lubrication on the seal. The friction burns the lip of the seal up before the lubrication in the primary can get there. It only take a second, literally.
Other seals that can cause leaks in this area are the large final drive gear seal in the face of the transmission behind the front belt pulley and the "Quad" seal that is inside the transmission. The Quad seal is almost like an O-ring. It's purpose is to prevent transmission lubricant from seeping out through the splines of the final drive gear. If the front sprocket splines wear and the sprocket gets the slightest bit loose, the compression on the Quad seal will be lost and the tranny will leak. The tale tell sign on this leak is that the transmission will leak a spot of oil about the size of a quarter or a bit bigger when you park the bike. If you wipe up the spot, it won't leak anymore until you either ride the bike or simply start the engine. Then it'll leak that quarter sized spot and stop. Check your lube level in your transmission.
Whenever I pull the inner primary and the belt on a Big Twin, I replace ALL the seals. Make sure you lubricate the lips on the seals so they don't cook before lubrication can get to the seal.
Good Luck
Steve
Jul 13, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
I changed tranny filter and pan gasket, still leaks, possible inner seal? any suggestions?
need to identify where leak is coming from wipe clean bottom of transmission and check trans lines ,dipstick tube, rear seal ,pan for leak or drip start van and let run drive around block than park and recheck trans for leak if leak by where engine and trans meet than front seal anywhere else fix and or replace front seal two choices first can try a trans leak additive follow instructions carefully or need to pull trans to replace seal
Feb 01, 2010 | 1998 Dodge Caravan
2004 honda shadow 600 VLX leaking fork seal bike has 600 miles on it should I replace left and right if only right is leaking.
check first to see if the leaking fork has any rust pitting on the chrome,if it has and its a very small blemish then fettle it off first,and just replace the leaking seal,as the saying goes..if it aint broke dont fix it,if the seals had been in the forks for years and the bike not used then consider replacing both..
Jun 05, 2009 | 1986 Honda VT 1100 C
Rear main seal leaks..does this affect transmission??
A leaking rear main seal will not cause your transmission to leak.
The transmission has its own seal and should not leak because of the engine rear main seal.
Due to the labor involved in replacing the rear main seal on the engine, it is best if you replace the front transmission seal at the same time if possible.
Installation varies on different vehicles but the principles are the same.
Apr 15, 2009 | 1997 Oldsmobile Regency
Tecumseh 5hp  Engine Snow King Mtd Blowers Lh195sp67517 Logo
317 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
