Question about GE JGRP17 Gas Single Oven
OVEN WON'T LIGHT GE JGBP30WEA6WW
I DON'T HAVE A MANUAL AND EVERYTHING WORK EXCEPT THE OVEN AND BROILER. a WEEK BEFORE IT TOOK FOREVER TO REACH THE PROPER TEMP THEN DECIDED NOT TO LIGHT AT ALL.
4 Suggested Answers
  • 71 Answers
SOURCE: Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Posted on Dec 25, 2008
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
TheMobilian
  • 8220 Answers
SOURCE: Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Posted on Feb 26, 2010
Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
Hi Ya, I have a GE XL44 the oven and broiler won't go on. Without having a meter to check the amps how safe to assume is it that I need to replace the igniter? Could this also be a fuse? I don't...
If your lucky you may have the same exact ignitor in the bake and broil section. If so you might want to switch them just to see if it works. Hope this is helpful.
May 13, 2011 | Ovens
I have a GE Spectra JGBP30WEA6WW and the oven doesn't ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 10, 2010 | GE Ovens
Model MGR5775QDB Everything works except Oven
Searched the internet until I found a service manual, which led me to the right area to look. still working
Jan 12, 2010 | Ovens
GE JGBP90MEB oven not lighting. Broiler working
Igniter needed to be replaced. GE fixed it the same day.
Sep 18, 2009 | GE Ovens
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
119 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
