Question about HP Pavilion dv6000z Notebook
Speed fan shows 95 C when i play games(poor frame rates)!!!!
I recently bought my new notebook.hp pavilion dv5-1106 ax.....amd turion x2-rm70...ati radeon hd-3750.
when i installed nfs carbon,fifa08,on a drive which already had two games in it.............i got poor frame rates in both the games.
i read on fixya only that if i store the game in a fresh drive,it will help n it did to some extent.........but my main problem is that in the HIGH PERFORMANCE mode temp is always around 85 C-95 C.n due to high temp ultimately frame rates again go poor.
n if i keep it in the power saver mode temp is low but performance really suffers.
i feel there can hardly be any issues with my heat dissipating system coz i just bought my notebook 2 months back...........n the fans also run properly.
i did hear AMD processors produce more but i feel this is too much or is it?
have i made a really bad choice by not going for INTEL CORE 2 duo......................but i did hear AMD was better for gaming so went for it.
mine is a 2 GHZ processor so i feel that also cant be the problem for the game.
is this temp really abnormal even for an AMD machine.....should i register a complaint with hp...................n will it really help?
  • 1 more comment
  • Shiv_rocker Jan 06, 2009
    well.......knotbeerdan....thanks for your response..........but i didnt feel that was the appropriate solution coz u just mentioned amd is poor............without any practical solution to my problem......sorry to say but thats what i felt.
    thank u world vet for ur response!!!!!!!
    it is sincerely appreciated!!!!!!!
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    You mention "Speed Fan" in your post title. Is that the program, Speed Fan? As it is, Speed Fan is notorioius for not handleing the fan and temp registers correctly on newer equipment as those registers may not be in the Speed Fan database yet.
    A better program is Notebook Hardware Control 2.0 this is freeware.
    On your battery, have you run a Battery Calibration yet? This is done in the system setup pages.
    The Turion is better for gaming but more of your heat is coming from the Radeon Display Adapter AND Hard Drive when in games. The hard drive itself will reach a considerable hot temp, around 50C and add to a hot box to begin with. In addition the CPU and your Sound Chip is also producing heat. On the main board itself when in High Performance mode and running an intense game, you will be getting heat from the Northbridge chip and the Southbridge chip. So al these pieces of hardware in your laptop in addition to the CPU are adding to your ambient heat. The temperature of the CPU is affected by the ambient air temp inside your laptop. This is a common issue today and the CPU has no affect on a laptop under this situation.
    The only exhause fan you have is on the CPU and it cannot dissapate everything alone. It is a good idea to have a well made lap top cooler pad with at least three fans and examine the preview photos of the cooler pad, at newegg for example, to see that their position will be near your hard drive, ram and cpu.
    You probably have an Asus board since they made the CPU and Display Adapter. You should have PC Probe available on the drivers disk or you can download it from usa.asus dot com and that program will read your board temps better than Speed Fan will and give you more accurate readings.
    You could lodge a complaint with HP, but expect something from them that is similar to this response I'm writing.
    It is a bit much to expect a laptop to perform like a deskton in extreme gaming programs. Almost all of us who run laptops have cooler pads and that is your best solution for bringing your temperatures down.
I had the same problem, a year and half old laptop burning like the sun under full load. Temperatures would soar above 100 degrees C.
Then I did some research and got the knowhow needed to open my keyboard (fairly simple for HP notebooks). I took out the fan and cleaned it for good. Used a vaccuum cleaner to blow the dust out of the heatsink fins. Later I took it off completely and applied new thermal paste.
Used RMClock to undervolt my CPU without any harm.
PRESTO!!! Idle and stressed CPU heat outputs decreased by a whopping 40 degrees. The temperature now hovers between 40 and 60 degrees C.
I'm happy now.
Posted on Jan 15, 2009
    Guru:
  • 859 Answers
I was going to mention that the laptop cooler pad I use has a hub cap like shape; like an inverted saucer. With this design is a fold out set of legs in one long figure. This can be used on a flat surface to provide some ergonomic comfort. It can then be folded down and locked and this saucer shape makes for a very comfortable feeling in your lap. It has one single fan in dead center and blow up against the bottom of the laptop and draws away heat that is always too hot to use in your lap. Like most of us, we put our laptops on heavy coffee table books and even these books get too hot for comfort. So, I like this inverted saucer shape because of teh large void it provides under the laptop and the feeling in your lap. This is made by Belkin (a well known and respectable company) and I got mine at Wall Mart for $28. When we were last at Wall Mart they were still selling this model so chances are good your local store may have some. They are white which is unusual, as most are black these days. The wite finish fits in with the Apple line of notebooks.
This is a link to the cooling pad at Amazon where it is selling for $16. As opposed to the pictures at amazon mine has a white USB cable and not black. This cooler has been in use and still selling a good two years after introduction in the market. This makes for a mature product where improvements have been made to problem areas as they have occured.
I have a friend who uses the Antec cooling pad and enjoys it. The main difference is quite noticeable as it is meta and your latpop can slip around on its surface if you have lost the rubber inserts to your laptop (something that happens all to often due to the heat affect on them). So, for the low cost to buy into a cooling pad this a good starter item and as your need may change, you can then buy bigger and more expensive as you so choose.
The Targus product has two fans and this link shows that product, also at Amazon, You will notice that this design is far different than the Belkin one and is more typical of cooler pad designs. The products with three fans may be a better more strategic purchase given the nature of your laptop and the fact that you really do need to attack the three hot spots on a laptop, Hard Drive, Ram and CPU.
I had meant to send you a link to Notebook Hardware Control. This is the link to the product's home page. They provide for non commercial use a free download. For the professional version it lauches as a service verses an exe and allows you to create profiles that can be saved and recalled. I know of no one who has purchased the professional version.
I hope all this help you out. I'd go ahead and claibrate your battery if you haven't already. It discharges your battery down completely and then puts a new charge on it, this is to eliminate any memory effect you may have... even on the lithium ion batteries. This process can take up to 16 hours in some cases, so run it when you know you will be away from the laptop and not be using it or need to use it.
Best Regards,
Worldvet
Posted on Jan 07, 2009
  • 100 Answers
Girl friend had the same problem Call HP support 18004746836 you may be eligible for a new motherboard. This model has suffered a bad bios overheating the motherboard and causing these problems!! The new bios makes the fan run ALL of the time but many have damage done. They added an extra year warranty for this problem. If its under 2 years old you will most likely get a new motherboard for free!!!
Posted on Jan 06, 2009
    Master:
  • 413 Answers
From my experience AMD seems to have poorer quality cpu's so one possibility is that you got a bad cpu. It would be a good idea to contact hp and see if you can have your machine replaced
Posted on Jan 05, 2009
  • 1 more comment
  • Dan rogers
    Dan rogers Jan 05, 2009
    I'm sorry if there was something i said but could you possibly tell me why you gave me an innapropriate rating?
  • Dan rogers
    Dan rogers Jan 06, 2009
    You asked if you should complain...I gave my two cents. You did not ask how to fix this or what is caused by this. Learn how to ask the right questions and you will get the answers you deserve.
  • Dan rogers
    and i have seen your other ratings so this answer doesn't hold water you rate everyone this way
Game doesn't run without dvd and doesnt run smooth!!!!
the first question, its a a copy protection, no its better to play with the dvd if you actually own the game.
the other question, lower the video settings and quality settings to get more performance on the cost of quality.
Dec 28, 2008 | HP Pavilion dv6000z Notebook
My notebook heats a lot!!!!!!
Hello, here is the deal, AMD and INTEL both have CPU's that have low heat. In your case you would have to buy a new laptop to switch from AMD to INTEL. The laptop motherboard take's only one socket type, for exp.. you would have to get another TURION at faster speeds or less speeds in the same socket family. Try to keep the vents open, sometimes the vents for the air from the fan come out the bottom not the back. You might want to invest in a laptop fan stand.
Dec 21, 2008 | HP Pavilion dv6000z Notebook
My notebook overheats!!!!!
I have never heard of that about AMD cpus, on the contrary it has always been the Pentiums who overheated, nevertheless, it does sound like you are running a little hot, I would suggest a laptop cooler like an Xpad, that should cool it down down at least 5-10 degrees, try it you will be amazed what a difference they make.
Amd turion x2 rm 70 mobile processor
I will be glad to share my little knowledge in this senario.
Basically, I am personally a fan of AMD processors who is the first to manufacture 64 Bit Processors for Desktops and Notebooks.
However, if you remember, Intel started concentrating on Performance and not on Speed after AMD was able to design processors which were able to outperform Intel processors with slower speeds.
So, you need to look into Performance and not into Speed of the Processor.
Coming to the processor installed in your notebook, it is normal but I recommend you to use Windows XP than using Vista since Vista need more RAM and processing power when compared to XP.
Also, Windows Vista Home Basic is the basic version among the Vista family with very little features.
Coming to the Heating issue, this is common for all Notebooks to heat up when used for long time since the Notebook parts are palced in a very small where if any part heats up, it is passed to other parts too.
Make sure that the Cooling Fan Vents in the Notebook are not filled with Dust.
You can find these vents located at the rear of the notebook from where the hot air should be emiting from inside the Notebook.
I recommend you to use a Vaccume Cleaner or Air Blower to blow away invisible dust which might be blocking the airflow.
Also, make sure that the Notebook is placed on a flat surface like a Table so that there will be air flow from the bottom of the Notebook and the Cooling Fan will be able to **** in the required air from the bottom and dissapate the heat generated by the internal components.
Also, check for any BIOS Update is available for your Notebook related to this issue and update with the same.
You need to contact HP Chat Support and get the exact BIOS Update for your notebook since updating the BIOS with incorrect Update will make the Notebook useless.
Hope this gives some idea about your doubts.....
Nov 02, 2008 | HP Pavilion DV5234US Notebook Laptop
Amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
Oct 30, 2008 | HP Pavilion DV5234US Notebook Laptop
Comparison amd turion x2 64 bit vs core 2 duo
x2 64 bits is faster, however, there not much of software support at this time.
2 duo is 32 bits. there are plenty of software.
you will not know the difference unless you are playing on line game.
wh don't you spend the mony on the memories.
Oct 26, 2008 | HP Pavilion DV5234US Notebook Laptop
I got an AMD turion x2 64 processor in my new notebook n after reading reviews comparison to core 2 duo i m really tensed!
You made a good choice. In the CPU arena right now, the difference between the two CPUs is a toss up. The slight advantages of one vs. the other in benchmark tests is nominal and actually artificial..
What happens with an AMD CPU is with the associated GPU onboard. And with a 64bit processor, the number of apps and games that take advantage of 64bit CPUs has always been limited but they are growing. This will only become more and more numerous.
The main architectural difference in the two was in how the two cpus communicated and the AMD was first to use a bus between the two cores and the Intel had to go to the onboard memory controller and back. That was in the first inception. Still, AMD has been far in advance of Intel and Intel has played catch up in tricks inside the cores and how the north and southbridge took advantage of the cores' architecture.
Needless to say, I'm an AMD power user and my gaming rig has an AMD dual core on an Asus/Nvidia board and an Nvidia PCIe 9800 GPU.
In the long run, all modern notebooks require you to own a pad cooler to use these in your lap or not, they all produce heat. So, just get a good one designed for your laptop so it snaps into place and will keep your rig nice and cool.
At a LAN Party you won't suffer from having a dual core AMD cpu, you'll hold your own and it will be an even playing field and the wins will go to the person with the fastest fingers... as it should be.
Sleep easy friend,
Worldvet
HP Pavilion dv6000z Notebook Logo
503 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
