Question about SanMax 2.5'' EXTERNAL ENCLOSURE KIT (HD227U2) Drive Case
USB Connection Issues
I have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. Sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. I do not have this issue using the firewire connections. I don?t know if I have a problem with the SanMax or if it?s operator problems. Also, how large of a HD can be used and are firmware updates available. Thanks, Cat
  • Anonymous May 25, 2008
    I have what I think is the same drive, although it says Mobile Disk on the outside and the model number is HD-338-Comp. It is a combo Firewire and USB and it worked fine last time I used it on my old computer, but now my new computer will not recognize it. It is supposed to be plug and play for Windows XP. I have the latest Service Pack (3). I tried switching it but to no avail.
    Scholar:
  • 125 Answers
Windows XP (no service pack) can only use 137 GB MAXIMUM. If you have a drive connected to the pC with XP, you will not have any problem if the data stored is less than 137 GB. If you exceed this limit, the entire harddisk will be wiped-out because the system will overwite the file allocation table. This limitation was solved by Service Pack 1 for XP and Service pack 2 for windows2000
Posted on May 24, 2007
    Genius:
  • 2,985 Answers
Cat this is your earlier problem reworded - I can see now that this is a dual device. If you can use it that way in Firewire mode leave it at that. However - is it possible that this is a 'switchable mode device and you have not discovered the secret of how to. If there is anything like a manual with this check it thoroughly or get into the makers tech support team
2 Suggested Answers
SOURCE: USB Connection Problems
Jackboy, that wasn't a very good answer and it is apparent you are unfamiliar with the SanMax HD-338 External Hard Drive Case which has BOTH USB and Firewire connectors.
I don't have the answer to Redfire's question, but at least we need to understand her situation. She's not getting USB and Firewire confused. She's simply saying that when connected as USB Windows XP has trouble "seeing" the drive and when using her firewire connection off of the external case, she doesn't have this problem and is wondering why.
Jim B.
Posted on Nov 12, 2007
HD-338-COMP external hard drive not mounting
It's likely your dealing with hard drive failure on your san max and you will need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Computers & Internet
2 TB G-Raid External Drive connected with Firewire cable is not recognised after Reboot my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 16, 2012 | Acomdata USB 2.0 2 TB External Hard Disk...
Sanmax hdd-338-cb usb drive is not being recognized
rlmahle
If the drive is not showing in My Computer then most likely the drive letter that it wants to assign to is already assigned to another device. The link below will show you how to change the drive letter on the device.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
May 01, 2010 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Firewire does not work usb works just fine, Using Win xp, my pc does not recognize the drive. I have 4 firewire ports on the pc, not all on one card.
are you upto date on your IEEE Drivers? please post your current Driver Version here.
found at Control Panel/System
Sep 03, 2009 | SanMax Computers & Internet
Accidentally deleted partition
Simple, Connect your HD and boot computer using win XP CD and try to create a partition again using unpartioned space ! - xome
Aug 21, 2008 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
Transferring data from a sanmax to my laptop w/vista premium
Lindy. Go to my computer on your computer and click on the harddrive. Then search within to find the programs you want.
Jul 06, 2008 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
SanMax portable drive suddenly, after 22 mths, not recognized by XP
may be partition table is mismounted,go to dos mode and run CHKDSK for your external drive .(press F8 after post and select dos mode)
ragards
prasanna
Dec 16, 2007 | Computers & Internet
You say have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. You then say sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. Fire wire is a different system with a different connector style- so it should not be in a USB port or a USB connector should not be in a Firewire device. Get you device and connections sorted The desktop display simply puts up a device it will not differentiate which USB or Firewire
May 23, 2007 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Computers & Internet Logo
760 people viewed this question
Top SanMax Computers & Internet Experts
Alun Cox
k24674
Are you a SanMax Computer and Internet Expert? Answer questions, earn points and help others
