Question about Roper RES7646KQ Electric Dryer
Red440sq0 electric dryer roper - Roper RES7646KQ Electric Dryer
3 Suggested Answers
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
SOURCE: Roper Dryer Won't Turn On
Ok...almost same problem...resolved by replacing thermal fuse by blower....so I guess the thermal fuse can just go with a little surge from opening closing door switch if it was already on its way out...or something...but simple fix anyway....thanks for giving me the order of things to try!
Posted on Jan 16, 2009
Roper dryer will not start
How to Troubleshoot a Roper Dryer That Will Not Start ' Home Guides ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Jul 14, 2016 | Roper Dryers
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
Dryer (Roper, electric) won't heat
Its probaly gone open circuit, however there is a thermistor that prevents it shorting out, you need to locate it and test it with an ammeter
Mar 25, 2010 | Roper REX4634KQ Electric Dryer
Roper electric dryer replaced timer
check the door switch if that is bad it will not start if that is ok there is a white fuse on the blower houseing in the back check it with an ohms meter
Mar 16, 2009 | Roper REX4634KQ Electric Dryer
Quick check list starting with the most likely to the mostly likely NOT:
Fuse edfbadd.jpgmounted on the blowers housing this puppy is wired in with the door switch. If the lint in the dryer gets to blocking the exhaust then this puppy gets all hot and bothered and melts, causing the whole machine to come to a screeching halt just as if you have opened the dryer door. Clever ain't it? Clean out the lint and replace this fuse.
Dec 31, 2008 | Roper RES7646KQ Electric Dryer
Emerso Dyrer doesn't give heat
Your issue is;
"I have an Emerson electric dryer model # RED440SQ0. The dryer spins but there is no help. Thanks for any help. "
Based on the information provided above, I am unable to access my database to provide you with exacting information. An invalid model number was returned... However, I have provided some common solutions to help guide you in your search.
This information is for a generic brand dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 23, 2008 | Dryers
Roper dryer
what do you mean wont cut off ?? the heat?? the drum? was this on the top part of the heationg element?
Jun 09, 2008 | Roper RES7646KQ Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Roper RES7646KQ Electric Dryer Logo
49 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
