Question about Pool & Spa
Zodiac barracuda shark unscrews itself
How that the Fall is here with cooler water temperature, my Zodiac Barracuda pool shark tends to keep unscrewing itself every 2-3 days. I have to fish it out of the deep end and manually screw the hose back into the shark so it can get back to work. Any ideas?
  • 366 Answers
SOURCE: zodiac barracuda G3 isn't pulsing
These cleaners have a diaphragm inside that opens and closes that causes the unit to travel. If the diaphragm is bad, it will just stay still. Right above the handle there is a nut, separate the top part of the cleaner and you should see a white tube. Push that white tube downward and pull it out of the bottom of the unit. You should see the rubber diaphragm, check to see that it is free of debris and if it is distorted. The opening inside the diaphragm should look like a fairly uniform ****, not a huge gap. If it looks like there is a large opening inside, replacing it will make it run like new. Hope this helps.
Posted on Nov 01, 2009
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
  • 366 Answers
SOURCE: Our Zodiac Barracuda pool cleaner isn't working
you may have a bad diaphragm inside the unit. Unthread the nut between the "wagon wheel" and the lower unit and remove it, push down on the white tube until it comes out of the bottom of the barracuda. Inspect the rubber diaphragm for debris and deformations. If the diaphragm has a large gap inside, it won't work properly. It needs to have only a small uniform gap, they can sometimes even look completely closed when they are new. Replacing the diaphragm will most likely make the unit run like new again.
Posted on Nov 14, 2009
  • 366 Answers
SOURCE: Barracuda Zodiac G3 is not pulsating. It's got
either some debris is caught in the diaphragm or it's deformed enough to render it inoperable. Unthread the nut just above the handle and pull it apart, then push the white tube downward until it comes out of the bottom of the unit. Inspect the diaphragm to see it there is any debris in it or if it is deformed. Usually the diaphragm has a uniform opening, if the gap is wide, it will not function. The most common problem is that the diaphragm needs replaced. Hope this helps.
Posted on Nov 19, 2009
  • 366 Answers
SOURCE: the zodiac works for seveal minutes, then the pool
sounds like you may have an air leak somewhere. If not from your zodiac hose, it may be in the plumbing itself. Check the threaded fitting on the suction side of the pump, check the pump lid o-ring, and depending on the pump, check the gasket between the hair/lint pot and the volute or seal plate (especially if it's a sta-rite).
Posted on Nov 22, 2009
Barracuda head keeps coming unscrewed from hose
Try wrapping white plumbers tape around the threads 3 or 4 times and then screw back together. That worked wonders for me when i had that problem.
Apr 05, 2013 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My Barracuda G4 keeps turning over after a few minutes. I've adjusted the weight position, but it keeps happening.
You can check your water flow and make sure that it is not too high, but if your pool cleaners flipping over, there is probably a rather sever issue. Zodiac recommends that you contact your local warranty location if the cleaner is still under warranty.
Mar 28, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My Barracuda keeps stopping after a while. Did the suction test and it is reading 3. Is this too low to keep it running?
3 is perfect. The diaphram is most likely the problem. If the diaphram is more than say..9 months old it can get bloated and not function properly. The only other problem could be is if the cleaner is a few years old the foot pad could be worn out and the cleaner can **** itself to the pool and not move. Most likely the diaphram though.
Nov 22, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My zodiac g3 does not cover the entire swimming pool
One of the most common problems with these pool cleaners is the hose. If the hose is not long enough, it will not cover the entire pool. You might need additional hose. Also, make sure that your hose is weighted correctly and the water pressure is correct.
Aug 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Has good suction but wont move
Sounds like a clogged or damaged diaphragm. Unscrew the nut just above the handle and push the white tube downward until you can see the white(ish) rubber diaphragm. It should not be damaged or distorted. there should be a small uniform gap inside and should not have any holes other than the two ends. Replace if necessary.
Apr 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
The zodiac works for seveal minutes, then the pool pressure goes down and the zodiac stops. when i remove the vac hose from the vac intake the pool pressure returns. i hav cleared the zodiac and ck each...
Nov 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Nov 16, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Pool & Spa Logo
106 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
