Question about Dell Dimension 3000 PC Desktop
I have windows xp professional and i have tried to do a systems restore to no avail. Though I can access safemode with no issues just cant access the internet, I need to know how to fix this problem.
  • Aaron Voegele Nov 08, 2012
    Also I dont have the reboot disk that came with the computer
  • Dell Master
  • 27,725 Answers
Im not quite sure i understand the problem
when you acess safe mode do you get a screen ?
if the screen is black you wont be able to get the internet unless you select safe mode with networking
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
post a reply if you need more help with this
hope this helps
Posted on Nov 09, 2012
3 Suggested Answers
mrninja
  • 600 Answers
SOURCE: Dell Dimension 3000 system recovery
AH yes, Kristen very familiar with your issue, it is trying to load the primary boot record from a device it dosen't see , ( re: a floppy thats not there) you need to check the BIOS and make sure the booting sequence is correct (re:disable floopy if one dose not exist, etc) please write back if you need help doing all of these things
Posted on Apr 18, 2009
  • 489 Answers
SOURCE: Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Posted on Jul 06, 2009
My computer says configure updates and then it automatically turns off
This will be a long process of troubleshooting and may end up of restoring your computer to a factory settings. You can try the steps below:
First is boot up to advance boot options, to do this follow the steps below: -Turn off your computer -After pressing the turn on button start tapping F8 key until you see the Advance Boot Option. -Try choosing Last Known Good Configuration if it fail try Safemode, Safemode with networking or safemode with command prompt, if one is successful use system restore to restore your computer to an earlier date but if it fails you'll need to use your Operating System Disc to use the repair option.
Here's how to access system restore incase you're able to access Last Known Good Configuration, Safemode, Safemode with networking or safemode with command prompt: Windows XP: Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
Windows 7 and Windows Vista: Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If you're on safemode with command prompt: At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER, System Restore window will pop-up then select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If all the steps above fails you need to use the recover disc or the operating system disc to do a repair on your computer. Revert back in case you need steps for using start-up repair.
Note: If the steps above and start-up repair fail there's no other option but to restore your computer to factory settings.
Apr 21, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Pc running XP is stuck in a loop attempting to boot in Safemode. I set it to do this after failed attempts via F8 setting. How do I get my xp to load up and log-in back? thx!
I had this same thing happen to me. I had messed up registry with a registry cleaner and made my main drive unbootable. Fortunately I have a 2ndary drive which I cloned my primary drive from. Assuming that you have a 2nd or back up drive that its bootable you can do 1 of two things physically switch the order of the cables so that it boots from the other drive first or press delete key during POST/BIOS and switch the boot order there. Even if you had to steal a drive from an old computer to boot from once you are booted you should be able to access data on the other drive (I was able to) Otherwise you may be in trouble...depending on the value of your data you may wish to enlist a professional.
Oct 23, 2009 | Microsoft Windows XP Home Edition
Virus Side Effects; Safe Boot; Drive Access denied
try to restore your system ;
start, all program, accessories, system tools, system restore and try to restore an earlier point which you will choose
Sep 14, 2009 | Microsoft Windows XP Professional With...
Error in WINDOWS PCDLIB32.DLL
To get rid of the rtutils.dll you can try the steps given below.
Turn on the system in safe mode by pressing F8 as soon as you turn on your system
Check the recycle bin to see you hav accidentally deleted the file. If so restore the file from the recycle bin.
If you have cleared the recycle bin then the best option would be to use a file recovery option. A software called Recuva is available. It is a file recovery software.
Sometimes the file could have been corrupted bya spyware/virus/malware. In this case run the anti-virus and anti spyware. This can help you detect the malware and restore the file back to normality.
else try to do a system restore
XP->
Start-> Programs-> Accesories->System tools-> System restore
Vista->
Click on windows (left side bottom) -> Type (System restore) in start program bar-> and click on the same.
If you are facing the problem after a software installation then try to uninstall the software and check for the error.
Try to clean up the registry
Try to update the drivers.
and if all of these don't work then try to download the dll file from the internet.
Jul 13, 2009 | Microsoft Windows XP Professional Edition...
Problem with botting my system......plese reply
The solution for this issue would be...
In order to get this issue fixed... What needs to be done is as follows...
1) Right click on My Computer...
2) Then in the drop down menu... Left Click on Properties....
3) Then you will get the system properties window...
4) In System Properties Window... Go to the Advanced Tab...
5) Under Advanced Tab Click On Startup & Recovery Tab.
6) Under Startup & Recovery Uncheck the option's which says time to display OS 30 seconds.. Uncheck both the options
Jan 22, 2009 | Microsoft Windows XP Professional
Cant rememebr adin password or safe mode password
If you do a google search on "Windows XP password hacking" you will find a lot of free downloads which will automatically remove the windows password.
Dec 12, 2008 | Microsoft Windows XP Professional With...
Having trouble with HP ..Windows XP
I suggest that :
  1. Press F8, choose command line (if you know) and backup any file that you need (copy to an external drive, pen drive, cd or other medium). Please skip this step if you allready have updated backups.
  2. you restore the windows XP with the original cd / dvd, and choose format disk.
  3. remove the cd / dvd when asked for reboot
  4. Restore your data files and update the operation system with Microsoft update.
Hope that helps. Please inform what hp model you have for further help.
Cheers,
Pedro
Aug 24, 2008 | Microsoft Windows XP Professional With...
Keeps looping into safemode
When restarting, try pushing F12 until the boot menu comes up and then choose "Last Known Good Configuration" or the Windows XP (or other OS) non-safe mode option.
Jan 05, 2008 | IBM ThinkPad A21m 2628 Notebook
Hellp me sir
Re-install XP over top of you old one. That may overwrite any bad data.
Nov 06, 2007 | Microsoft Windows XP Professional With...
Dell Dimension 3000 PC Desktop Logo
12 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
