Question about Home
I have an apollo hydro heat water heater I need to replace. Its a 50 gallon with a 65000 btu. Which water heater is compatible to the Apollo?
2 Suggested Answers
amsnare
  • 4 Answers
SOURCE: i have an apollo hydro heat system, i need my heat on in order to take a hot shower
RFog, I'd say a 80 gallon hot water tank is much closer to your needs....An easy one.
The rest are difficult.
This I know - the water must be decent and neutral, otherwise, nothing but problems.
Posted on Jan 29, 2012
My apollo spa galaxy II D20Nj will not heat past 85 can you tell me what I should do or part to get to fix this serial #BSJLJEG
make sure spa setting is at 104 degrees if at 104 degrees see control system if ok change temp sensor either in heater or control unit
Dec 07, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My Apollo hot tub stopped heating and the first set of jets are not working and both seemed to have gone out at the same time. The second set of jets and the air are fine. Does anyone have any ideas of...
You're pump #1 has failed. Your spa has 2 water pumps and an air pump. Number 1 pump pushes water through the heater. Pump 2 simply supplies the second set of jets with water. The air pump simply pushes air through the air jets.
If pump one fails you will have no heat and the first set of jets will not turn on. Pump 1 is the most prone to failure because it kicks on any time the spa needs to filter or heat. This happens automatically every day so pump 1 works much harder than pump 2. Your heater has a safety mechanism that makes sure that water is flowing through the heater when it kicks on. If there is a problem with pump 1 your heater will not kick on. There are stickers on your #1 pump. Get the model number off of the sticker and order a replacement pump from a web site like www.spapartsdepot.com. If you give them the model number of the pump they can send you a replacement. I'm 100% sure that's the problem. I'm not affiliated in any way with the web site I mentioned but I'm pretty sure they will have the pump you need. Good luck!
Mar 24, 2013 | Apollo Pool & Spa
I have an apollo hydro heat system, i need my heat on in order to take a hot shower
Jan 28, 2012 | Home
My Apollo Rainier hot tub's heater doesn't seem to work - I get a FH message on the display. Please help!!!
HL generally stands for high limit fault which means a sensor is opening the heater circuit due to too high a heat reading. Common causes for such a fault start with poor water flow due to dirty filters which in turn allow the element to overheat. If necessary, replace the filter elements to restore proper flow.If flow issues are not the problem, try looking at the heater itself however you should probably call out a professional at this point as most remaining issues to check are within the controls and the heater and if you are not familiar with working on these components you should avoid trying to repair this yourself.
Oct 22, 2011 | Pool & Spa
We have a 83 Gal. Rheem 41V50 40,000 Btu - What do we replace it with? It is leaking
The model number you gave is for a 50 gallon tank, not 83 gallon.
50 gallon ones are readily available, including the same model..
Oct 20, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Apollo 2600 printer installed ok, but wont print
I don't believe Vista is compatible with Apollo any more. I know OS XP will work
Jan 30, 2008 | HP Apollo P2600U InkJet Printer
Home Logo
94 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
