Question about Iomega ZIP 250 External ZIP Drive
Trying to get my files from an iomega 250 External Zip Drive, it doesn't show up on my Windows 7
I have a new cord Parallel to USB to make it work on my Windows 7 but It doesn't show on computer. It does cause Computer to download a driver. I read that if you have the wrong Driver, it will not show the zip drive. I have a zip disk that should install, it sounds like it works; but nothing comes on screen. I can get the old Disks copied for 69.00 at Staples. I Downloaded a Software w32-x86-402 but it said it will not work; so I didn't install. Is there another solution of should I just pay the $69 and junk the stuff. Anyone know. Thanks Martha
3 Suggested Answers
  • 13433 Answers
SOURCE: USB 250 zip drive not displayed
Hey, lost connection with you
Thanks,
Ekse
Posted on Oct 29, 2008
graphsupp
  • 13 Answers
SOURCE: Need a driver for macintosh
If its a really old zip drive then its SCSI and not usb. It may even be parallel for a pc. To avoid having to deal with drivers or anything like that. You could probably find a cheap external USB zip drive. You dont need drivers for this, only for the older ones.
Also, you might go to an apple store and get some kid to burn a cd from it, if its just a one time thing.
Hope this helps!
Posted on Feb 25, 2009
Where can I get appropriate USB cable, i.e, parallel to USB not the original parallel to parallel?
So you have an old Zip drive with a parallel port? You can't connect that using USB. Nor can you connect that to a computer running any version of Windows newer than XP.
Two options:
1) Buy a USB version of the Zip drive and use it to read your disks. Used, USB Zip drives seem to run around $35 or so.
2) Get a computer using an old version of Windows. If it doesn't have a parallel port, you should be able to buy a PCI card with a parallel port on it.
Once you're able to access the files, copy them onto a USB thumb drive. For $10, you can get a 32 GB USB drive, which should hold everything from at least 320 Zip disks.
Sep 23, 2015 | Iomega Zip 100MB (31714) External ZIP...
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
I am trying to connect a Iomega Z100ATAPI Zip drive to my Windows 7 laptop.
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Mar 23, 2012 | Iomega 100MB IOMega ZIP Drive Internal IDE...
I own a 250 meg. parallel port external Zip drive. This drive could once be used on DOS-based computers with software called GUEST.EXE and some drivers, with GUEST selecting the correct driver and...
Recomendation: Replace for a external hard drive, The Zip drive is outdate. With theExternal HDD you gona have more space than a Zip drive, really much more.
Dec 13, 2010 | Iomega ZIP 250 External ZIP Drive
I have an external Iomega 250 zip drive with a USB connection cable but do not have the power cord/transformer. Where can I get a replacement and will this drive (model Z250USBPCM) work with an iMac?
Yes your model will work with an iMac conveniently. The replacement chord can be gotten from any computer hardware store around. All you have to do is take the unit there so they can access what particular chord is going to function for it.
Hope this solution has been helpful?
Aug 25, 2010 | Iomega ZIP 100 MB SCSI (10011) External...
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
Hope this helps!
Jan 18, 2009 | Iomega Zip 100MB (31714) External ZIP...
Thanks,
Ekse
Oct 29, 2008 | Iomega ZIP 250 External ZIP Drive
Iomega zip drive problem
I'm trying to re-install iomegaware zip 100 & it tells me it does not support windows 2000 so I need to update drivers. Can you please help me figure this out as I rely on my zip for backups. I have version 21.1.
thanks very much
Marlene
Dec 31, 2007 | Iomega (32453) External ZIP Drive
Iomega ZIP 250 External ZIP Drive Logo
61 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
