Question about Polaroid FLM-1911 19 in. LCD Television
Jimmy/com picture stays white till it warms up. has sound
Transmission not shifting into high gear since abs/4x4 code
answer to any 4l60e trouble ' GMT400 - The Ultimate 88-98 GM Truck ...
www.gmt400.com > Street and Track > Transmissions
Mar 5, 2011 - Before guessing at transmission problems, check the fluid level (car warmed up, ... that do not show up as PCM codes (like shift A&B solenoid failures, for example). ... 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for ...goes into 3rd gear: Reaction planetary is worn out due to high miles or ...
GMC Jimmy Transmission Problems - Edmunds
forums.edmunds.com > GMC > GMC Jimmy
Dec 20, 2013 - 1998 Jimmy After truck warms up shifts hard between 1st and 2nd gears. any ideas ... The ABS light stays on,the engine light stay on, the speedo doesn't work, .... I have a 1990 S15 4x4 Jimmy with a manual 5 speed transmission that went out. .... While driving it will only shift into 2nd gear and 3rd no overdrive. and usually ... Ford F-Series Transmission Problems - Edmunds
Dec 18, 2013
Buick Rendezvous Transmission and AWD Problems - Edmunds
Dec 18, 2013
Dodge Dakota Transmission Problems - Car Forums at Edmunds.com
Dec 18, 2013
Ford Transmission Problems - Edmunds
May 14, 1998
More results from forums.edmunds.com
Automatic Transmission May Not Shift Correctly at High ...
repairpal.com > Problems > Toyota > 4Runner
Feb 03, 2016 | Cars & Trucks
1997 jimmy car shut off while driving. replaced
SCAN IT SOUND LIKE IDLE SPEED CONTROL PROBLEM.BUT I AM LOOKING AT VACUUM LEAK AT THE INTAKE MANIFOLD BROKE VACUUM HOSE. OR FUEL INJECTORS SEALS LEAKING.
May 12, 2010 | 1997 GMC Jimmy
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Have sound but no picture
inverter board has failed try shop jimmys on the web
Sep 16, 2009 | RCA L26HD31 26 in. LCD HDTV
Hessitation when damp outside
sounds like you have a bad ignition wire replace wires and plugs and try it
Mar 10, 2009 | 1998 GMC Jimmy
Sony KV-27TW75 Black and White Picture
this is usually due to bad ground check cable line comming into tv and
CHECK/RESOLDER CONNECTIONS IN TUNER WHERE CASING IS SOLDERED TO PCB NEAR 4TH FEED THRU BACK FROM ANTENNA INPUT
Feb 04, 2008 | Televison & Video
Philips Magnavox 9p6040 c102
IC's on convergence bd. 1st try opto coupler philips part# 483520988561 actual part# to buy HCNW136 some replace all 3 IC's philips# 483520987834 actual# MC34065p and philips# 483520987712 actual# SC78104 search google to buy.Datasheets at datasheetcatolog.com
Nov 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Polaroid FLM-1911 19 in. LCD Television Logo
23 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
