Question about ASUS P5LD2-VM Motherboard
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
If I include the Raid in the BIOS - Boot XP O/S - os hangs and will not boot into windows unless I remove the Raid in the Bios or Physically remove the raid from the motherboard. - 3 WD Drives each drive is 500 Gig connected to Sata 1 Sata 2 Sata 3 nothing connected to Sata 4 - IDE is a WD 80 Gig IDE Drive with O/S Sata is a Raid 5. Updated drivers Bios etc.
  • 1 more comment
  • mbmccabe Jan 05, 2009
    if I remove disconnect the IDE I just get the message that there is no operating system.
    IDE 80 Gig is the operating system
    Sata 1,2,3 ports are a Raid 5 ASUS P5LD2 on board Intel Raid.
  • raven447 May 11, 2010
    Not the fogiest. try disconecting the IDE and see what happens. I will be interested to see what the solution is.
    Sorry I'm no help here.
    P.S.: XP sucks. When I was a tech I had the opinion that MS should have stuck to 98 and 2k and just released service packs after that, alterninately just released a product that just worked.
  • Anonymous Mar 14, 2014
    Motherboard P5LD2 raid driver windows 7
    President:
  • 2,692 Answers
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Posted on Jan 05, 2009
Phoenix bios D686 BIOS phoenix 1998 020124471 2 RAM, each 128 MB I am not able to run OS(windows XP, Ubuntu 5.10, Ubuntu 8.10 ) setup completely. I made hard disk bootable from other...
System incompatibility issue. I have mo bo that will not work with XP but works fine with Win 98. Happens and nada you can do about it except get mo bo that works.
Aug 28, 2017 | Computers & Internet
Windows xp safe mode stuck at mup.sys. Please help. Thanks.
If you are having a problem booting safemode then Windows is corrupted and will need to be repaired/re-installed. You can insert the windows xp disc and re-boot the computer. It should ask you to boot from cd-rom drive. If it does not you will need to change the boot sequence in the BIOS for the cd-rom to be the firsst boot device. Once you are able to boot the Windows cd you can try to repair the windows installation if the repair does not work you will need to format and re-install windows. hope that helps.
Sep 17, 2009 | IBM ThinkPad T60 Notebook
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Apr 16, 2009 | ASUS P5LD2-VM Motherboard
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and...
Just follow these simple steps:
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Good luck and have a nice day!
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Want to run both Raid 5 (4 drives) and a single SATA boot drive
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: http://rapidshare.com/files/186891601/P5B-Deluxe_1238.rar :)
Feb 07, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Software raid/ide
it won't touch them, it should ask you which partition you want to boot from, or which version of windows if your boot.ini files are on the same drive.
Dec 18, 2008 | Computers & Internet
Help find driver
hi! download you motherboard driver from here!
www.nodevice.com/driver/P5LD2-VM/get34084.html - 15k
drivers.softpedia.com/get/BIOS/Asus/Asus-P5LD2.shtml - 55k -
www.driverfiles.net/Bios/ASUS/P5LD2/download/page,sh,30052,172,6,.html - 60k -
Jul 18, 2008 | ASUS P5LD2 Motherboard
Need drivers
Here's the web address for drivers for your motherboard:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5LD2%20SE
You need the chipset drivers and possibly the Audio and LAN ones, too. There are specific ones for your operating system.
Unless there are serious problems with the motherboard, you don't want to mess around with the BIOS.
Good luck.
Jul 17, 2008 | ASUS P5LD2-VM Motherboard
Dell d600 video problem
Forget the non-sense.
  1. Remove the battery
  2. Open the RTC Battery compartment
  3. unplug the RTC battery
  4. Press the power button to dissipate stray voltage
  5. Re-install RTC battery and cover
  6. re-install main battery
  7. Re-boot and enter set-up to change date time etc.
Apr 17, 2008 | Dell Latitude D600 Notebook
Computer won't boot
did you load the raid drivers?
Dec 05, 2007 | ASUS P5LD2 Motherboard
ASUS P5LD2-VM Motherboard Logo
392 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
