Question about Dayton Heating & Cooling
Dayton wall furnace 3E291. Where can I purchase a gas valve?
4 Suggested Answers
  • 15 Answers
SOURCE: Venting a Dayton 4E454 24,000 BTU gas furnace
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
Hope this helps.
Posted on Dec 02, 2008
  • 3248 Answers
SOURCE: I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Posted on Dec 08, 2008
  • 13626 Answers
SOURCE: no ignition on dayton gas furnace. how hard is it
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Posted on Oct 31, 2009
Looking for how to hook up a thermostst
That all depends on how old the system is, wires colors change over the years,.
May 19, 2017 | Dayton Heating & Cooling
2YV14 need to find a new replacement fan blade and hub for a dayton wall heater model #2YV14
Hello Jeffrey Messenger,
Dayton is a big name product available at GRAINGER.
Electric Wall Furnace,
Recessed or Surface, 240VAC, Watts 9200
Replacement Parts
H
elp finding replacement parts?
Please call 1-800-GRAINGER
(1-800-472-4643)
The 2yv14 is a well known heater... sadly it has been
MANY years since I have purchased any
Dayton equipment... but GRAINGER RETAIL
OUTLETS WERE The reliable PLACE TO GO.
(see below).
GRAINGER
https://www.grainger.com/category/dayton/ecatalog/N-1z13ntg
DAYTON-Electric-Wall-Furnace-2YV14
Electric Wall Furnace Recessed or Surface 240VAC Watts 9200
Carnac the Magnificent
Mar 22, 2017 | Dayton Heating & Cooling
Wall heater, model 3E291. Where can I obtain a natural gas valve?
Sounds like a Grainger number and they should be able to obtain one for you.
Oct 31, 2015 | Dayton Heating & Cooling
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Our MGTA 07 EMAES Dayton gas furnace has a crack in the condensate pump. Where can we find a replacement?
Hello, here is a link to where you can purchase condensate pumps http://www.plumbersurplus.com/Cat/Condensate-Pumps/284/List
Jun 08, 2011 | Dayton Gas Furnace Heater
No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
Oct 31, 2009 | Dayton Gas Furnace Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Dayton 3e735 standing wall furnace
Wall furnace? maybe and maybe not! if there is a way it would be on the gas valve and be labeled (though it might be hard to read). often the adjustment screw is under another screw but always labeled.
Feb 03, 2009 | Dayton Gas Furnace Heater
Fault Code on Dayton Gas Furnace
This happens when the furnaces tries to light to many times and doesnt succeed. If you stand in front of the furnace while it is coming on, you will be able to hear the problem. If its an electronic start, there will be a clicking sound, followed by the gas valve opening to start it. If it has a pilot light, make sure it is lit, then listen for the gas to come out, it will make a hissing sound. If no gas is coming out, first double check to see if the gas is turned on to the unit, if it is, then its possibly the gas valve. Oh, if it is electronic, and you hear gas, but dont see a glow inside the furnace, or no glow or gas, it could be the ignite. Hope this helps.
Jan 07, 2009 | Dayton Gas Furnace Heater
hope this helps
Dec 08, 2008 | Dayton 511 Utility Heater
Heating & Cooling Logo
183 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
