Question about Samsung DMT300RFS Builtin Dishwasher
I have over-level water error on my DMT300RFS/XAC samsung. How can I solve it?
2 Suggested Answers
spucketts
SOURCE: Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
Posted on Jul 25, 2012
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
What is error code LE?
An LE error code means problems with the motor. It can either be load issues, excessive suds, thermal overload protection, or a new installation. To solve this motor problem, you must first uncover the underlying cause.
Mar 24, 2015 | Samsung 24 Dishwasher DMT300RFS
Samsung dmt300rfs gaskets
Yeah, those gaskets tend to stretch with age (and hot water). They need to be replaced with new gaskets.
Jun 01, 2014 | Samsung DMT300RFS Builtin Dishwasher
Where is the float on my dishasher
he float on all dishwashers is on bottom, inside, where the water sits. It controls the water shut off point. They are usually not removavble for cleaning. You simply wipe around them and make sure nothing has accumulated or lodged underneath that would stop if from floating freely.
How do you fix the samsung dishwasher dmt300rss low water sensor
First be sure to disconnect/shut off water and power before beginning. Facing the washer pull it out. On the left side, outside, low, there is the water level sensor. It gets gunked up and trigger lever gets stuck. Clean it out and you will be good to go.
May 29, 2014 | Samsung DMT300RFS Builtin Dishwasher
If I had to guess, I Would think it's a gummed-up water level float chamber. Once you pull it out and clean it the dishwasher should run fine.
Pull the entire dishwasher out and lay it down on its side (facing the door, tip it over to your right)
There is a little white box. Inside that little box is probably a bunch of sediment and glop, but along with all the glop, there is a wing-shaped float that probably can't move due to the glop. Hold the whole plastic thing under the sink faucet to rinse it out.
You will probably have to take off the tub pan in order to pull off the drain hose that's attached to the back of this chamber. But this is far better than having to pay for a service call.
After rinsing, put it back in the dishwasher, this should solve the problem.
Dec 18, 2013 | Samsung DMT300RFS Builtin Dishwasher
Over-level water error on samsung DMT300RFS
My DMT300RFS had the same symptoms, but the float chamber (fc) has a somewhat different configuration, and is white plastic, vs clear. PULL THE MAIN POWER CORD!!!! To remove the fc, first go inside the tub, and remove the round fixture that holds the larger chamber on the outside. The fc attaches to it. The round fixture is not threaded, and gentle use of channel locks will pop it off, after about a 1/8th turn (see arrows). My fc could nnot be removed unless the entire assembly is take off the outside of the tub. After the entire assembly is removed, disconnect any electrical connections. I had two. Release the clip holding the fc to the complete assembly (looks somewhat similar to the one pictured above--thanks capnjosh) then take the retainer clip off the fc feed hose, disconnect the hose and remove the fc from the dishwasher. It's tight! There are several capture clips holding the top onto the fc, but I decided not to fuss with them (breakage concern) and simply used hot water and dish soap to rinse the fc till gunk stopped coming out. Back together and all seems well! Best wishes.
Nov 02, 2013 | Samsung Dishwashers
Where is the water level switch located on the Samsung 300 series dishwasher?
There is an anti-flood valve on the bottom looking like an upside down teacup.
Aug 26, 2013 | Samsung DMT300RFS Builtin Dishwasher
Mar 18, 2012 | Samsung DMT300RFS Builtin Dishwasher
What is the part number for the water level switch
Hello Kevin,
the part number for that water level switch which is called the flow meter or flow sensor is DD32-00004A
i dont know if your local appliance parts store carries Samsung parts but it could be ordered online at searspartsdirect.com,repairclinic.com
GENE
Nov 07, 2011 | Samsung DMT300RFS Builtin Dishwasher
Samsung DMT300RFS Builtin Dishwasher Logo
160 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
