Question about Durabrand DUR7 Portable DVD Player
Durabrand 8.5 dvd player
Dvd player screen says 'loading' and will not read disc.
  • Anonymous Dec 05, 2007
    My husband bought the player in the states and brought it home to S.A.
    Of course all our dvds are the wrong region. At this point i need to copy the discs region free to watch them.
    To top it all we have misplaced the remote for the machine.
    Help????
  • FrankandP Dec 08, 2007
    Screen says "loading," but is never loaded and we are unable to watch a DVD.
    Genius:
  • 2,985 Answers
Is it the correct type of disc? Whilst these devices will play almost all 'commercial' disks In many cases 'burned disks' Cumputer Data disks and audio disks are a No No The manual/packaging will tell you which. You could try a Lazer cleaner disk. Failing that it looks as if the device is failing and needs replacing - I doubt if there is a repair option.
Posted on May 23, 2007
SOURCE:
Player reads DVD as bad
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Jan 02, 2018 | Durabrand Audio Players & Recorders
Tip
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
We have a Durabrand portable DVD player, the issue we have is once we place the dvd in, the screen reads loading, then reads no disc. We have tried several discs. Any free troubleshooting suggestions?
hello
use a cd/dvd lens cleaner kit or if that does not work, you will need toopen lid, access the lens pickup, and clean the lens directly, using isopropyl alcohol with cotton sticks.
anyway if these all dont help you need to replace pick up with a new one. i recommend original spare parts as those sold on ebay mostly chinese production with low quality and durability.
kind regards
Feb 20, 2011 | Durabrand PDV-709
I have a Durabrand dual screen 7" portable dvd player Model PDV-722. Has worked fine for over a year. Now it just spins and says loading. Then it will say disc error. I have tried several discs and have...
Looks like your optical sensor is gone. And considering the price of the PDV-722 replacing the optical unit is not an option. By the other hand I have a burned slave monitor and I would be happy to buy yours to complete my set, which is reading DVD's very well.
Sep 19, 2010 | Durabrand DUR7 Portable DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Disc error
Durabrand went out of business last November. Wal Mart has been exchanging DVD players that have been having trouble with one the is of equal or greater value.
Sep 15, 2008 | Durabrand Portable DVD
Dvd plays cd's but not dvd's - gives no disc message
I have a durabrand portable dvd player we've owned for about 1yr and had just started messing up. When you put the dvd in it says it's loading and shows the blue dvd screen it just wont come on but you can hear it trying, please help what could be wrong?
Aug 12, 2008 | Durabrand DUR7 Portable DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Will not read disc
Threw it out. Bought a different more reliable brand. Thanks for nothing.
Apr 18, 2008 | Durabrand DUR7 Portable DVD Player
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
47 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
