Question about LG LSC26905TT Side by Side Refrigerator
Had burning smell than dispenser switch in freezer door stopped dispensing water or ice. Ice maker still fills and makes ice. Lock switch works (unlocked). Light switch on panel does not turn on the light.
  • Bruce Freedman Nov 15, 2012
    How can you tell it isn't just the water solenoid switch? By the fact that the light doesn't turn on? And are there instructions for installation that come with the part? Thanks.
    Top Expert:
  • LG Master
  • 9,472 Answers
The control board for the dispenser has gone out and needs to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
  • Bruce Freedman Nov 21, 2012
    I got the part but can't figure out how to remove the dispenser panel to get to the control board. The exploded few doesn't show any screws, and I don't want to break it by prying it off without first asking how to do this. Thanks.
rickzilla
  • 706 Answers
SOURCE: Ice maker panel came loose on LG LSC26905TT fridge
Please use the attched link to get the service and user manuals for your fridge. There are exploded views there as well so that should provide you suffiicient information to reinstall your panel. You can also get part numbers etc for replacements if that is necessary.. Hope this helps you...
http://136.166.4.200/contents/Fridge/LSC26905.htm
Regards,
Rick
Posted on Nov 27, 2008
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
Joe Onley
  • 363 Answers
SOURCE: lg lsc26905tt ice maker makes ice, but wont turn dispenser
you can look to see if something from the freezer dropped into the chute? it may have blocked the exit. Is this all new ice or has it been a while since you used it? Maybe the auger in the bin is stuck?
Posted on Aug 27, 2009
  • 13 Answers
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Posted on Mar 21, 2010
  • 26 Answers
SOURCE: Ice maker on an LG American Fridge Freezer doesnt work- why?
it can't freeze
Posted on Jun 12, 2010
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doe's not fill up with water to make ice
just bought a brand new side by side with ice and water dispenser i have water coming out of the door dispenser but the ice maker tray is not filling up with water can someone help me
Jan 01, 2009 | LG LRSC26940ST 36" Side-by-Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
LG LSC26905TT Side by Side Refrigerator Logo
75 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
