Question about Kohler K-690-VS Vinnata kitchen sink faucet K-690-VS. Kitchen Faucets vibrant stainless. In brushed bronze K-690-BV, polished chrome K-690-CP, brushed nickel K-690-BN, oil rubbed bronze K-690-BRZ. Vinnata kitchen sink faucet K-690-VS. 11-13/16" 30 cm swing
Leaking Kohler Vinnata kitchen faucet.
I have the Kohler Vinnata 691 kitchen faucet. I have replaced the cartridge in the handle at the base of the faucet and am still finding water leakage as before. Are there other parts I need to check?
    New Friend:
  • 51 Answers
You must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Posted on Dec 18, 2012
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do I open the body of K-10430 apart to replace the valve cartridge kit that's leaking
    The handle has a allen set screw loosen that until the handle comes off then the bonnet nut will unscrew revealing the bonnet cap and washer the cartridge should be under that most kohler's require a special tool to remove cartridge(turn water to faucet off prior to working on faucet,also note how everything is removed it needs to be replaced in same order especially the cartridge,also you should use plumbers grease to coat all seal when replacing everything).
    Jun 03, 2011 | Kohler Model 10430: Fort® Single-control...
    I have a Kohler Fairfax 12176 kitchen faucet and it is about 4 years old. It is starting to leak water out of the spout for a split second on occasion when you turn the water on. As time goes on, it is...
    Kohler K-79402-CP aerator kit
    Kohler K-78250
    Kohler 1001100
    You might try to replace aerator on end of spout if water is leaking around it, or you might try to replace cartridge. VALVE (CORALAIS AND FAIRFAX)
    K-GP77548
    $14.80 List Price
    Call Kohler if you need more info.
    Dec 16, 2017 | Kohler K-12176-PB Fairfax Single Handle...
    Kohler Fairfax single control kitchen sink faucet
    Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
    Good Luck and please rate 4 thumbs up for the free answer.
    Mar 19, 2010 | Kohler Fairfax Single Control Lavatory...
    I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
    turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
    Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Leaking kohler faucet
    Where the spout pivots on the main body, there are a couple of washers, you can replace these washers pretty easily by removing the handle and then the "cover" from the unit. The water has to be shut off before you do this. I would take this oppurtunity to replace all the washers.
    Mar 08, 2009 | Kohler K-15176-PT-7 Coralais...
    Kohler K-690-VS Vinnata kitchen sink faucet K-690-VS. Kitchen Faucets vibrant stainless. In brushed bronze K-690-BV, polished chrome K-690-CP, brushed nickel K-690-BN, oil rubbed bronze K-690-BRZ. Vinnata kitchen sink faucet K-690-VS. 11-13/16" 30 cm swing  Logo
    900 people viewed this question
    Top Kohler Home Experts
    Donni Steen
    john h
    Tim Whalen
    Are you a Kohler Home Expert? Answer questions, earn points and help others
