Question about Panasonic Computers & Internet
Hi, I recently bought panasonic toughbook CF-C1 from a car boot sale, which is ask me a password, someone help me to reset the password. thanks
  • Panasonic Master
  • 7,627 Answers
If i understand you correctly you bought a laptop out of the trunk of a car. You could try here for info:http://www.panasonic.com/business/toughbook/business-rugged-toughbook-C1-convertible-tablet-pc.asp
Posted on Nov 09, 2012
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
sxcss
Posted on Apr 30, 2008
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Andrew
Posted on Dec 25, 2008
Geekman
  • 32281 Answers
SOURCE: need to reset or erase admin password
There are Linux password removal programs on the Internet. It is designed to remove passwords on NT, Win 2K and XP.
You copy the program to a CD and boot up from this CD. It allows you to reset or remove the users and administrator passwords.
Google search for these programs "password recover" There is another solution. You can reinstall windows and this will give you a clean computer and possibly better performance without the accumulated junk/rubbish. Don't forget to get/download all the device drivers (eg. video, audio, modem,NIC etc.) before you start.
Posted on Jan 11, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    How to reset a password on a panasonic toughbook c-1
    You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
    Jan 10, 2013 | Panasonic TB C1 I5-520M 2.4G 2GB...
    Does anyone know the default BIOS password for a CF 27. Thanks
    Don't know the generic password, you probably can get it if you contact Panasonic about this, but you can however reset the password. To reset the BIOS password read the information from this link.
    In case of your laptop the easiest method would be using software from Hiren's Boot CD.
    Nov 13, 2010 | Panasonic Toughbook CF-27 Notebook
    Hi i had bought a Panasonic cf-52 from someone they owner gave it to me with a password he told me the password but when i got home i had forgot it and now i cant reach him is there a way i can fix this
    YOu can reset bios password with 2 method.
    (1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
    (2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
    Put jumper in 2-3 position then again put it in 1-2 position then check .
    Let me know if you need more assistance.
    Thanks.
    Nov 10, 2009 | Panasonic ToughBook 52 Notebook
    On boot up a safeboot apears and asks for password i bought this secondhand and its been trouble from day one anyone out there please help also bios has had a password done as well so cant get into that...
    if you are able to open motherboard then simply remove CMOS bettry for 10 sec and put again then password will reset...if you dont open motherboard then ask me?????
    Apr 03, 2009 | Panasonic Toughbook CF-51 Notebook
    Need to reset or erase admin password
    Jan 10, 2009 | Panasonic Toughbook CF-51 Notebook
    Need to reset the password
    Make A boot disk from a working Windows 98 machine. After you make the boot disk, copy the MS 'debug' to the floppy.
    Boot the laptop from the floppy.(this might not be possible due to a setting in the BIOS.)
    Search online for MS Debug +clear CMOS
    Run the Debug program and type in the commands exactly as written.
    reboot, and you should be able to go into the BIOS by holding F2.
    That's it.
    If you can't boot from the floppy, remove the hard drive. the computer should boot from the floppy, no matter what the BIOS setting is.
    Nov 25, 2008 | Panasonic Toughbook CF-27 Notebook
    Bios password
    usually you can reset the password by taking out the battery and removing the AC adapter, then either pulling out the small watch sized battery on the motherboard and leave it off for a few minutes or move a jumper on the motherboard to reset the bios. If that isn't possible or doesn't work there is a list of backdoor passwords available here. http://saptha.com/blog/?p=32
    Jul 24, 2007 | Panasonic Toughbook 47 Notebook
    Computers & Internet Logo
    421 people viewed this question
    Top Panasonic Computers & Internet Experts
    micky dee
    Computer Repairing
    Computer Repairing
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
