Question about Refrigerators
See all gsh22jfxl ww model solutions
Water line not dispensing water
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
You will need to replace the "water valve" on the back of the unit. The solenoid is no longer energizing. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
How do you get the water dispenser on a GE side by side model GSS201EPD WW to work?
Chances are that the=> WR57X10050 Water Inlet Valve has become defective on the dispenser side of the valve.. I am here should you have questions, Thanks John T. Appliance 911
Jun 28, 2015 | GE Refrigerators
How do you fix the water dispenser on a GE side by side refrigerator model GSS201EPD WW
Here are a couple of possible problems. Most common one is a defective water inlet valve. It is the plastic assembly at the lower back area where the house water connects to. On dispenser systems it is actually 2 valves in one unit---half lets water in to icemaker---the other half lets water dispense at door. It is electrically operated so if half goes bad , the other half can still work. If bad it needs replaced as a complete unit.
Second possible problem with some GE side by side models is they had problems with the water line in the door going to the dispenser sometime would freeze up. They came out with a heater kit that needs installed in the dispenser area to defrost the water line. Call GE service with your model number and they may be able to tell you if you need that kit installed.
I have a GE GSH22JFTA WW that will not dispense water. Does dispense ice, crushed and cube. Panel is not locked. What part do I need? Thanks!
in the back of the fridge there is a module with the solonoid on it to open and close for the water, and it usually get damaged because of hard water, it is about 15.00
Aug 29, 2014 | Refrigerators
I have a Hot Point refrigerator model No. HSS25GFTA WW. I changed the filter but water still not coming out of the despencer, every thing else is working normal.
Sometimes you will need to purge the air out of the line after changing the filter. Just hold down the water dispenser for a few seconds every hour or so.
Jan 30, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
No water at dispenser
apply hair drier to spout and surrounding area for a minute every ten minutes , after about an hour the ice that has formed will be loose enough for the water to come out of spout
Mar 28, 2009 | Hotpoint HSS25GFP Side by Side...
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
