Question about Samsung SASCLX3175FN CLX-3175FN Color Laser Printer/Scanner/Fax/Copier
My clx-3175fn has torn paper in fuser unit. How do I take machine apart.
Paper jam 2. When I opened the unit from the back, the paper was already torn. A little more than half of the sheet was down low in the back (closer to the back of the paper tray); the remainder of the paper was wrapped around the orange "fuser unit", close to the point of exit. I tried to get the paper out from under the scanning unit, though it was nearly in shreds on the exiting end. By removing 4 screws in the back, I am able to loosen this "fuser unit" though I am unable to get it entirely free from the machine, despite retracting the cylidrical extension on the left. Can anyone tell me how to get that unit out so I can get all the paper out, blow out the dust, put all back together, and try to print again?
4 Suggested Answers
  • 220 Answers
SOURCE: Samsung CLP-315
paper exit sensor faulty,common problem with this printers.
Posted on Jun 24, 2009
DosHog
  • 168 Answers
SOURCE: Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Posted on Aug 13, 2009
Douw
  • 91 Answers
SOURCE: Paper Jam 1
there is most probly a pease of paper in side the fuser unit.See if you lift the top cover just under the scanner, the hole top lifts up!!!!!!.in the back you wil be able to see the fuser.Be carefull IT IS HOT!!!!!!!see if you can get eny papers in there.And try to take it out carefully.Otherwise will have to strip it to take the fuser apart to clean it up
Posted on Jun 09, 2010
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Scan unit open or paper jam2
In my case the printer was in a closet (as I do not want to keep it in my room and Wi-Fi allows me to do so) and it seems that the fusser heat attracted some unwelcome guests... Mice... Their faecal matter has fallen into all the bits and ends that sense the paper coming out of the fusser... Due to the heat they dried up and the printer started throwing "Scan unit open or paper jam2" errors... Took a while to figure out and vacuum all the faecal matter out and the printer is now running... Was getting ready to start taking it apart...
Jun 29, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Paper Jam 1
Jun 03, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Printer says "scan unit open or paper jam 2" Hav...
Dear
The printer paper jam-2 cover may be opened or not locked properly.
This door is at back side of the printer.
Thanks.
May 21, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
I can'r find the paper jam in the printer. screen
If not picking up the paper then it the Pick-up Roller just above where the paper tray is. Remove the paper Tray and Tip Printer back so you can see under the Printer. Take some rubbing alcohol and clean off the rubber roller
Service Manual found here Free...
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Won't let me fax, copy or print. it tells me paper jam 2 look in
paper jam 2 generally denotes the fuser unit. thats at the back, the bit that heats up, theres a flip up/down cover that once opened should show you if theres any paper in there, also check the sensor, little black arm, move freely and be sprung, if the sensor is missaligned it will denote a paper jam even when there is none be careful to let the fuser cool down, printer unplugged for 10 minutes or so, 180 degrees will hurt.
Sep 24, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Paper jam after 1 page prints
fuser paper out sensor faulty.req new fuser.
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung SASCLX3175FN CLX-3175FN Color Laser Printer/Scanner/Fax/Copier Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
