Question about Dyna-Glo (PPH16-LP) Utility Heater
Starts fine runs just about two min then kicks off and excesive fumes
  • Dyna-Glo Master
  • 2,460 Answers
Would say burners and pilot all need cleaning , blocked jets .
Posted on Nov 12, 2012
My 95 ford f150 runs great till it warms up it seems then the fuel pump looses power n shuts down wait few mins kicks back on runs fine till few min later
Sounds like your ignition module it is common on fords to do this when its cool it will start and run fine but once it heats up the truck dies until you let it cool down again and then your up and running till it heats up again. Some modules are mounted on the fender others are mounted with the distributor have it checked and let me know how it went.
Aug 26, 2014 | Cars & Trucks
My mazda diesel fumes into the air filter and clogs it with oil.what causes this please
clean out crank case ventalation system if this is all clean and oil level is correct then carry out a compresion test to check for piston ring blow past causing excesive crank case pressure
Dec 30, 2013 | Ultraviolet Heat Shield Covers For Causes...
2002 Malibu stalls while driving, doesn't over heat. But can start smelling gas fumes before it stalls. usually wait about 5 mins then restarts. in higher elevation runs fine but in lower elevatio
It sounds like the catalytic converter could possibly be almost completely plugged up not allowing the exhaust to leave the engine like it should. It just builds up in the cylinder head and when it gets too much in it built up and there's no where to go, it'll stall the engine. By letting it sit for a few minutes, it gives the exhaust time to find a way out and the car will restart.
Mar 27, 2013 | Chevrolet Malibu Cars & Trucks
Riding my ttr 250 Runs fine then just dies when ded no headlight starter or anything. I wait 10 mins kick it and starts rides about 2 Mins and dies again what could it be?
Maybe trash in your carb. Take the carb off and clean every hole you can find. Put it back together and reinstall. Should work fine.
Jan 22, 2013 | Garden
What is causing white smoke that smells like strong fumes coming out of the exhaust pipes, when engine is idling and it reduces while the engine is running.
indicates an engine oil comsumption, for excesive piston rings wear or valve seals, maybe your engine neeed to repair
Sep 05, 2010 | 1992 Lexus Ls 400
Car leaks somethings when first starts--shut engine off and restart no leak Can smell some sort of gas fumes Had radiator checked-it's fine Recently had water pump, fuel pump replaced, tune up and some...
might be a small split or loose circle clip on a pipe, which would leak a little as pressure builds then lowers again. try letting your car run for 10 mins on a level dry piece of ground then look under it for any dripping or puddles or fluids.
Apr 22, 2010 | 1998 Oldsmobile Bravada
Truck ran fine, turned off for 5 min the it would
listen to see if the fuel pump is kicking on.
Jan 02, 2010 | 2002 Chevrolet Silverado 1500
Maytag performa dryer won't run right
bad motor,,should have change it when you had it open,,thats the overload you hearn inside the motor,,when hot it clicks off and when itcool it will run a while than click off...again...need help changing ..
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't run right
The motor in your unit has to be replaced. The centrifical sw can't seem to keep the motor going. The shaft may spin freely, but once power is present the shaft locks up therefore your over amping the motor and it then trips the breaker. Since you already had the unit apart you will do fine replacing the motor. Good luck
dmparenti
Dyna-Glo (PPH16-LP) Utility Heater Logo
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
