Question about DeLonghi Coffee Makers & Espresso Machines
DeLonghi Magnifica ESAM4200 - Steam pressure function not working properly
I have a DeLonghi Magnifica ESAM4200 Bean to Cup machine which has developed a fault with its steam function. Recently it has become very slow to steam milk enough to froth it properly for a cappucino. I regularly maintain the machine and have run another descaling cycle to see if this would help, but not improvement. During the descaling cycle the pump on the steam arm worked well to pump out water. So far as I can tell the coffee is still hot and so is water coming out o the steam function, it just sounds and looks as though the steam pressure is too low. I am going to try to make use of the Delonghi Milk Clean which I did not know existed until today, but I would be very grateful. My machine is now 3 years old.
  • Sera Nov 10, 2012
    Just thought to add that I am going to: 1) Make use of the Milk Clean 2) Make use of descaler again 3) Attempt the pipecleaner in the steam pipe bit. But what I'm wondering is whether or not I would be better off replacing the steam arm or any other parts (heater?). I'd really appreciate any advice. Thank you!
  • Sera Nov 12, 2012
    It seems that a lot of water, not steam, is coming out of the steam arm and the machine is slow to heat up to make coffee. Could this be the pump or coupler?
3 Suggested Answers
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Posted on Oct 08, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Why won't the steam function work on my brand-new out of the box DeLonghi Magnifica Espresso Machine?
The steam heater is probably not working. Check your manual to see if there is a fuse or reset switch for it. If that doesn't work, return the machine to where you got it for an exchange.
Aug 30, 2015 | DeLonghi Magnifica Coffee Makers &...
Delonghi problems
I had a similar problem which was solved by replacing the infusor. I was able to find a new one on eBay for about $40. Hope this helps.
Jul 28, 2014 | De'Longhi Magnifica Esam4200 15-Bar Bean...
Boought brand new delonghi magnifica 3300 and did everything the directions say, it turns on, and the motor runs, but no water comes out when we try to run the water for the first time out into the cup...
Read instruction manual first before assuming there is problem. It happen we are not familiar to the operation of the machine the troubles becomes- "operators errors rather than machine errors".
If you already read operating manual and still not yet understand. Call their service hotline, ask something about your problem.
It easy as that! I hope my advice help you.
Apr 04, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Hi I have the Delonghi Magnifica ESAM4200 which I haven't used for a couple months, went to use it tonight and the grinder worked, the lights came on in the order they generally would, but I dont seem to...
hi turn unit on as normal ..when its ready to wash through turn the steam knob fully open that will sort it ... then shut it off again. job done ,,,,run open for about 15 sec.. any repairs needed we do a postal service .
Feb 28, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica bean to cup machine blows fuses
at a rough guess when you twisted the switch you have shorted out the power wire to the ground wire creating a dead short
take it to an appliance repair shop to fix what you broke
Sep 08, 2017 | DeLonghi Coffee Makers & Espresso Machines
No water light on new delonghi magnifica
I had the same problem.
As the machine is brand new, try washing the infuser under the hot water tap and then dry it. I then made a 2 cup long coffee and the red no water light stayed off.
Mar 24, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
112 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
