Question about Water Heaters
System lockdown led - Water Heaters
  • Water Heaters Master
  • 5,245 Answers
Tempra 24 installation. No hot water. No power led on fron cover. Is the led supposed to be on all the time or just when water is ran?
First, check the circuit breaker. Also, did you upgrade to heavier wiring and a double 60 circuit breaker when you had this installed?
Aug 15, 2014 | Stiebel Eltron TEMPRA 24 Tankless Water...
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
System lockdown stops after 5 minutes
Which type and brand water heater.
Look on label.
Copy following link for troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also post coherent detailed question with brand, type etc on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
For Tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Nov 08, 2012 | Water Heaters
Unit periodically shuts off. LED flashes "13."
it sounds like a dirty flame sencer rub down with emrycloth or fine wool steel if that dosent work need new pilot assembly.
Jan 21, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
How can I reset the thermal cut off
Take off front cover, on the top of the cylinder(s) in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Dec 05, 2010 | Stiebel Eltron TEMPRA 12 Tankless Water...
Just bought a water heater with electronic lighter,will not light
check comp board for led light and a reset on board ??? LED will also flash and give code with problem look for code on door panel or close bt and fallow instructions????
Oct 20, 2010 | Rheem 81VP6S/430126 Water Heater
I have a ge smart water electric water heater and
does it not have adjustments for heat settings. I thought these were smart as in maintaining heat with demand
Mar 05, 2010 | General Electric GE SmartWater Household...
No hot water in our tankless water heater
You may find this info helpful.
http://www.stiebel-eltron-usa.com/pdf/install_tempra.pdf
If you don't find what you need, you will need to contact them directly.
Apr 05, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
