Question about HP Photosmart M425 Digital Camera
Lens error m425-12
Lens won't move
  • 2 more comments
  • Anonymous Jan 22, 2009
    The lens is out fully and will not go back in!!! Says lens error on screen
  • Anonymous Feb 08, 2009
    lens won't detract when powered off
  • kotalee Feb 26, 2009
    as soon as i switch it to picture mode the lens comes out and goes back in and says lense error
  • frostll May 03, 2009
    as soon as I turn on the camera it says lens error M425-12 and then turn off.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
  • 5 Answers
SOURCE: Lens error M425-12 (7f80) appears/ camera shuts down
if the blue light flashes 4 times Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Posted on Jan 19, 2008
SOURCE: Lens Error M425-12 (7F80) on HP M425
Try taking the SD card out and restart the camera. Also, make sure the batteries are fully charged. There is also a firmware upgrade indicating a problem with the lens getting stuck.
Posted on May 15, 2008
yea.. i also got sand in my camera and i have thje same problem... there is no help anywhere on the internet for us :(
Posted on Jul 20, 2008
SOURCE: Lens Error M425-12 hp
i found the solution of this error real if any one wanted to know it please call me at 0125155342 or contacted on my e-mail
m_50eng@hotmail.com the price isnot heigh.if any one didnt showen me online send e-mails to me and i will replay.if i didnot replay call me sure you will find me.goodbye..
Posted on Aug 22, 2008
  • 102366 Answers
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
We dropped our camera today, and it was only fron about like.. 2 feet, aand now the lens thingy won't go back in and it says "lens error." I think I can see the problem with it, but we dont...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 18, 2011 | Nikon Coolpix S203 Digital Camera
I turn my dmc-fh27 camera and the lens won't come out. it is trying to move but it will not budge and the screen says "System Error (Zoom)".
Warning: This is only a last resort if you no longer have a warranty.
I used a variety of different methods, but here's what worked for my camera. Apparently the lens was just off the track.
1. Turn on the camera, and smack the back against the palm of your hand to get the lens to come out.
2.Hold the lens out until the "error screen" comes up.
3. Take the camera with the lens facing towards you, and use your thumbs to push on the lens.
4. Push firmly until the lens "clicks".
5. Turn off camera, then on again.
6. Hopefully cry tears of joy that you fixed it.
Jun 12, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
HP Photosmart M425 Digital Camera Logo
242 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
