Monitor flashes no signal twice then goes to sleep.
    Sergeant:
  • 286 Answers
Check the connection from your CPU to monitor.
Posted on Nov 08, 2012
Matampong
  • 153 Answers
SOURCE: monitor goes to sleep no input signal only 1 mo old
Normaly the monitor is not picking up the signal from the PC, it could be VGA cord is not connected, faulty, or the video card is faulty,or the monitor is not compatible to the PC. It could be one of my suggestions. Trouble shoot by connecting your monitor to another working PC and see what happens.If not the VGA cord is faulty and not picking up signal from the PC. Hope it helps.
Posted on Jan 22, 2009
SOURCE: monitor goes to sleep and never wakes up
I have called HP Technical Support 6 times about this issue and have logged at least 14 hours into the issue. The things they have done are turn all sleep settings in the "Power Options" in the control panel to "never". The problem persisted. Today, they sent my problem to the complaints department, so maybe they will have the authority to do something for my 5 week old setup.
For me, the monitor was in the "other devices" part on the device manager (go to start menu and type device, and the device manager will show up). I went to HP's website to the support and drivers spot and found a patch for the My Display program. This will allow you to uninstall your monitor, just right click the monitor under "other devices" and click uninstall. After you uninstall, restart and your computer will recognize the and put it under "monitors" in the device manager with the updated drivers. After I did this, the monitor hasn't gone to sleep.
Posted on Apr 02, 2009
  • 31 Answers
SOURCE: VGA no input signal, monitor is going to sleep
try this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061509&cc=us&lc=en&dlc=en&product=3351967
Posted on Sep 15, 2009
  • 31 Answers
SOURCE: Hp w1907 Monitor going to sleep
try the link provided
pravinbhavsa
  • 348 Answers
SOURCE: No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Posted on Mar 07, 2010
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
I changed some setting for the computer resolution and now my monitor just says no input signal..the hard drive turns on and then goes into sleep mode and says no input signal. How can i fix this problem?
Possible reason is that input signal goes out of range that probably a Screen refresh rate that the monitor cannot handle. Instead of bursting into flames, the monitor shuts itself
down as a protection feature. Look at the monitor manual if you got one.
Safe Mode should allow the monitor to work in the problem account.
Try this.
Boot in Safe Mode (see below)
Switch users to the problem account
Right click the desktop
Select Properties
Click the Settings tab
Click the Advanced button
Click the Monitor tab
Select: Hide modes that this monitor cannot display
Select a different Screen refresh rate
Click Apply twice and then Click OK
Or try this:-
power on the system and press and hold F5.
When a screen appers with some option, try to find a option something realted with VGA setting.
Click that option and let pc start normally.
It will surely work
Dec 10, 2010 | Hannspree HW191D LCD Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
My Computer boots and montitor says Going to sleep and flashes VGA : NO signal and goes off
Check under "Power Options" of the control panel of Windows that "Turn off Monitor" is set to "Never" Also check under the advanced tab of "Power options" that "When I press the sleep button on my computer" its set to "Do Nothing"
This will most likely solve your problem. the sleep button may be stuck on the keyboard causing the pc to quickly go into sleep mode
Nov 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Why does my monitor say "no signal" when you try to us my computer after it has been on sleep mode?
The computer turns off the signal to the monitor after it goes into sleep mode. You can adjust the power settings in the computer to not turn off the monitor.
Sep 21, 2009 | Acer X193W LCD Monitor
Monitor goes to sleep no input signal only 1 mo old
Jan 21, 2009 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
