Question about Dryers
G9P2BTAUC7030T My ceiling fan and light work with the remote, but presently both are not working even with the wall switch. What could be the problem? And what can I do to fix this problem?
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
SOURCE: Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
Posted on Jun 04, 2008
SOURCE: Huntington Bay Ceiling Fan W/lights & Remote operated. # HD 361054
The remote for the ceiling fan has 4 switches inside the battery compartment- look there. I had the same problem, turns out that when I replaced the battery one of the switches was inverted by mistake. Now it looks like 1 and 2 on, 3 and 4 off - and everything works.
Posted on Mar 02, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
Posted on Dec 24, 2009
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
May 30, 2008 | Hampton Bay 52 In. White Redington...
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Wall switch
I had this same problem (sort of) - my daughter lost the remote to our fan and it would not work from the wall switch. What you have to do is go up to where your fan is connected to the ceiling, slide the canopy down, and remove the remote transmitter. Then just rewire the fan normally - white to white, black and blue to black, and the ground wires together. Turn on the power and your fan light should work with the wall switch. You will have to pull the cord for the fan to work.
Jan 07, 2008 | Honeywell HFS641P Stand (Pedestal) Fan
Dryers Logo
308 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
