Question about Panasonic FV-08VKS1 WhisperGreen Ceiling Mount 80 CFM
Re: wiring the FV-08VKS1
Not including the ground, there are four wires coming from the fan, black,white, and two reds.  Can a three wire romex be used to connect fan to wall switch?  I would assume the fan's two reds would connect to the one red in the romex, which would then connect to the hi/lo switch in the wall switch.  The black would connect to the on/off switch at the wall.
  • 3 more comments
  • egispan Jan 05, 2009
    I think the efi link has an old wiring diagram.  There are two red wires coming from the fan - see attached wiring diagram from the installation instructions that came with the fan. Thanks.
  • sam704 Feb 01, 2009
    I'm replacing an old fan with this model. My old fan has two wires. It sounds like I need to add a set of wires that are hot all the time to run in both modes. If I tie the red wires together won't the fan stop running as soon as I turn it off at the switch? I'm looking for a clearer explanation on how this is wired up. Thanks.
  • Tripp REa May 11, 2010
    Confusing because this wiring diagram for fan shows only one red coming from fan at Junction box...
    http://www.efi.org/wholesale/installatio...
    Are you sure you are supposed to have 2 reds? possible one is looped or got cut?
  • Anonymous Mar 31, 2014
    I just bought a os31ou auto on sensor switch for my wall my old wall switch only has two wires white and red will this switch still work what wires do I hook up
  • 37 Answers
The black and white in the fan box are the main power and neutral for normal (low speed) of the fan. The two reds are the signal wires. It is basically a switch loop. You will actually need a total of 4 conductors (plus a ground) in order to run the high and low speed of the fan. The four conductors consist of 1) power from one switch to power up the fan, 2) neutral, 3) signal going to second switch, 4) signal going back to fan from second switch in order to run high speed. Without four conductors you can still run the high speed only by tying the two red wires in the fan together. This would be like always having the second swith in the on position. Hope this helps.
Posted on Jan 23, 2009
  • Mike Krall
    Mike Krall Jun 02, 2015
    Do the black and white need to run through an accessible switch, or does the circuit breaker perform that function? Asking because it seems odd to have to switch on the constant, low power aspect.
    And do I have this right... the two red signal wires override the low power setting and put the fan on high (80cfm), then, when that switch is turned off, the delay timer keeps the fan on high for the set amount of time. ???
Four wires from ceiling. red, black, white and ground-hampton bay w/remote has three wires. green,white, black. how to proceed?
Bk -BK
WH - WH
Gr - Gr
The red wire should be capped off. If this doesn't work, switch the red & black wires.
Aug 31, 2014 | Dryers
Which from the red or the black wire comeing from the stove, is the hot one
Since you have a red wire you must have 10-3 romex. 10-3 has four wires. Three jacketed wires Red, Black, White and a bare copper wire. The is Red and Black are your two 120 legs (both hot) white is neutral and the bare is ground.
Jul 13, 2011 | Whirlpool RCC3024 Electric Cooktop
My girlfriend has a leviton illumatech IP106 that keeps "not working". after a number of months. It is operarting a standard dining room 6 light chandelier. A couple of her friends have replaced this in...
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Oct 15, 2010 | Leviton Decora Light Dimmer Switch
How to wire to attic fan? Old Sping loaded timer has two wire connections Marked LINE and LOAD . There are two Romex- Three wire cables with Black , White (Common) and bare (Grd) wires coming into this box...
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Jul 10, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
WIRING DIAGRAM
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Nov 15, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Panasonic FV-08VKS1  WhisperGreen Ceiling Mount 80 CFM Logo
4,101 people viewed this question
Top Panasonic Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
