What corrective action for error code C6950? - Office Equipment & Supplies
  • ricardo nenoki
    ricardo nenoki Sep 12, 2015
    they said for contact support to fix that problem
    maybe neet to change some broken parts
"no slack"
Corrective Action Tectrix Climbmax
Error Code Reason Suggested Action 5 No Slack Enter test mode and test switch, adjust switch, inspect display cable for cut or crimp
Tectrix Climbmax Error Codes
Mar 16, 2014 | Tectrix Remanufactured Climbmax 150...
Error code 105
Info for Error code 105
105. (01101001) Phase 2 to 6 - Comms Error Time Out
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Note: If the product is an IW, the wrong Motor Control Module may
have been fitted. Replace with a compatible part.
Phase 2 to 4 and Phase 6
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor (Phase 5 and 6).
Action: Replace Rotor Position Sensor. If this corrects
the fault, refit the original Display Module or
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Quaternary Source: Rotor Position Sensor.
Sep 26, 2013 | Fisher and Paykel Washing Machines
Tech sheet missing need help with codes
Your Error code is 94
81. - 95
. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106
106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
Control Module.
Phase 2 to 3
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Feb 21, 2013 | Fisher and Paykel Washing Machines
What is a code 240 and a code 130
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Action: Ensure the correct rotor for this phase of machine has been fitted
Jun 03, 2012 | Fisher and Paykel Washing Machines
What is code 89?
81. - 95. (0101xxxx) Phase 2 to 3 - Display/ Motor Controller.
See fault code 106
104. (01101000) Phase 2 to 6 See fault code 106
106. (01101010) Phase 2 to 3 - Display to Motor Controller module
Communications Errors (Phase 6 IW also)
These faults are reported when the Display module detects an error in the
communications between the Display module and the Motor Controller module.
Primary Source: Display module.
Action:
Replace Display module.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module. If the new Motor Controller module corrects the fault, refit the original Display module.
Feb 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
Message d'erreur code 11:11
Error code indicating that Trailing cable faulty, replace it. But technical skills required to replace this spare..
Dec 14, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Please help me ??? system error
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two
installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the
EIO card.
n If this Error Code disappeared after removing the Hard Disk
Drive, then switch the Printer OFF and reinstall the Hard Disk
Drive, making sure that the two installation screws are
completely tightened. Switch the Printer ON again. If this Error
Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
n If this system error continues to appear after replacing the EIO
card or the Hard Disk Drive, then replace the Electronics Module
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
Apr 06, 2009 | HP DesignJet 1050c InkJet Printer
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Problem
Description:
Firmware Error.
disappears.
information.
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
Error 5
http://www.ok.is/vefmynd/HP%20Color%20LaserJet%202820%20user%20guide.pdf
Here is the user manual.
See page 225 for error codes and corrective action.
Note: Most error codes start at 50.....
Feb 08, 2008 | Office Equipment & Supplies
77 people viewed this question
jasbo
jasbo
