Question about Car Audio & Video
Avlex 2460B PAHS Amplifier what kind of fuse is needed
Need to replace the fuse on the Avlex 2460B PAHS Amplifier.
    Master:
  • 689 Answers
The same fuse you took out of it,
Posted on Nov 09, 2012
2 Suggested Answers
  • 156 Answers
SOURCE: i need to know what
You need 20A fuses times two!
Here is a manual for the amp just incase you need more information.
http://www.lanzar.com/manuals/VIBE226-236-246-256-266-276-286-416-426-436.pdf
Posted on Oct 03, 2010
One set of B speaker outputs not working
What kind of amplifier are you working with? I need more information to make an educated guess at your problem. Here is a basic list.
Make sure that when you are changing cables around that the system is powered off. I can't stress that enough. If you ever open your amplifier make sure that it is unplugged first. There is enough stored and live energy within a amplifier that it can KILL YOU... Be careful and don't touch anything if you don't know what your doing.
Make sure the power is turned off before you attempt any of these.
(1) Check your speaker wires and make sure they are correctly attached.
(2) Swap the B wires with the A wires checking to see if it could possibly be your speakers.
(3) With the power off and the unit unplugged check the internal fuses. Most good amplifiers have at least 3 slow blow fuses. One main and one for the A and B channels. That does not take into account all of the other fuses that can be located on the individual PCB boards that make up your stereo.
(4) If it is a fuse you can replace it but if a fuse is blown it is usually an indicator of more serious problems.
(5) Take it to a professional and have it fixed or just simply replace the unit if it not worth saving.
Good Luck
Dec 14, 2012 | Audio Players & Recorders
I need to know what amp fuse i need for my yamaha htr5840 receiver. i pulled out the blown one, but it only says 125 v. it does not tell me the amps.
The power consumpyion for yor amplifier is 350W / 440VA and the 2 switched AC outlets at the back panel can handle up to 100W, totally 450W. I suggest you to use a 5A / 110V fuse and in case burn down use an 6A / 110V fuse. DON'T INCREASE these values, you may damage the amplifier.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 13, 2011 | Yamaha HTR-5840 Receiver
Turn it on and blows fuse replace fuse and plug it in and it blow
You need to have the receiver serviced. The fuse is blowing because some part in the power supply or amplifier section has failed. A service technician will need to troubleshoot the unit to determine what parts need to be replaced.
Jul 10, 2009 | JVC TH-C50 System
I need to know what kind of fuse my amp takes...
IT MAY MEAN THAT IT TAKES (2) 25 AMP FUSES
IF YOU HAVE THEM OUT SEE IF IT SAYS WHAT THEY ARE OR OPEN IT UP IT MAY SAY IT ON THE BOARD OR THE FUSE HOLDER OR LOOK @ THE SPECS ON THE AMP SEE WHAT THE TOTAL CURRENT IS YOU CAN ALWAYS START WITH A SMALLER AMPAGE LIKE 10 -20 AMP FUSE ALWAYS GO SMALLER
Feb 15, 2009 | Sony GR-6.1m Gravity Mono Channel MOSFET...
Need help
If the fuses only blow after remote turn-on voltage is applied to the amplifier, the amp probably has shorted output transistors. If that's the case, they will need to be replaced.
If you're interested in repairing it yourself, read through the following page.
Amplifier Repair Primer
Let me know if you have any other questions.
Aug 26, 2008 | Kenwood KAC-7251 Car Audio Amplifier
Amp fuse
There are two 40 amp fuses in the unit I have.
May 19, 2008 | Logic Soundlab CPX1820 Car Audio Amplifier
Fuses
I'm not sure what kind (aka shape) fuses they are, but the manual says there 2x 20A fuses.
Mar 10, 2008 | Boss RIP-895 Car Audio Amplifier
Sentrek car amplifier
The remote turn-on wire for an amplifier connects to a switched power source. If the head unit has a power antenna lead, or amp control lead, use it. If not, the remote lead can go to a power source that is switched with the ignition key. No matter the source, you need to fuse the wire with a 1 amp fuse at the point where you connect to the power source.
Oct 22, 2007 | Car Audio & Video
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
