Question about ASUS P5kpl Se Motherboard Intel G31 Lga 775
Please enter Setup to recover BIOS setting CMOS Date/Time Not Set Press F1 to Run SETUP Press F2 to load default values and continue
I have replaced the battery on the motherboard and reflash it ,hoping that would fix the problem but it has not done so. If I go into the BIOS and set the time and date the system does not remember the settings and the same window appears on rebooting. If I press F2 and continue with the default values everything is fine until I come to reboot again. I should say that the computer has run very well for a long time and no new hardware was installed just prior to the onset of this problem. I look forward to hearing from you guys in due course, Thanks and best wishes,
2 Suggested Answers
dlundmark
  • 797 Answers
SOURCE: I INSTALLED A NEW CMOS BATTERY BUT STILL NO EFFECT
Just replacing the battery will not set anything. You have to do the setting of the values. If you can run setup by pressing F1, then do that and set all the settings and then save before exiting. Make sure you save the settings by choosing the correct exit and re-boot option.
If the settings cannot be set nor saved, then make sure the poser is off or pull the plug from the wall outlet, then short the bios with the jumper to short the bios. This will reset the bios to the default settings. Turn on the system and then go to the bios settings and set the settings. Then use the reboot option to save the settings.
Posted on Nov 06, 2009
Hello, I went into my bios settings and did something wrong now when I start up my computer it takes me to the mi bios megatrend screen at the bottom of the screen says driver bad press f2 to resume f1...
go back into the BIOS by pressing F12 and look for the set BIOS to default values or something along those line. save those settings and reboot..
Please give feedback...
Dec 18, 2012 | Lenovo Computers & Internet
Bad check sum cmos
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Hi, I really need your help, please help me. I get this CMOS Settings Wrong CMOS Memory Size Wrong Press F1 to Run SETUP Press F2 to load default values and continue ... and my keyboard doesn't work ...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Oct 04, 2010 | Asrock P4I45GV R5 Motherboard
I have an 5 year old computer with an ASUS P5P8500 motherboard, i have been getting start up errors everytime i turn on the computer. I get the following erros: CMOS Setting Wrong CMOS Date/Time Not...
Did you set the correct time while you where in the bios?
You may also have a virus infection that is messing with your system time/date settings to prevent your security programs from updating.
IF you cant start even in safe mode, you may need to try a live linux distro to scan your computer.
There are special live distros that are just for this very occasion.
Try this site for info and downloads http://njlinux.blogspot.com/2008/01/virus-scan-windows-using-linux-live-cd.html
Sep 16, 2010 | Computers & Internet
I INSTALLED A NEW CMOS BATTERY BUT STILL NO EFFECT AFTER THE SHUTDOWN WHEN I RESTART IT THERE IS AN ERROR ..LIKE THIS CMOS SETTINGS WRONG ...CMOS SYSTEM TIME/DATE NO T SET...PRESS F1 TO RUN SETUP...PRESS...
Nov 06, 2009 | ASUS P5PE-VM Motherboard
Cmos
You need to press F1 and go into the BIOS to setup and detect everything. You will need to set the date, verify it detects your hard drive and memory, and enable/disable items as you need for your system.
Once it looks good, do a Save and Exit.
Jan 16, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Bios checksum error. How to solve it?
If you are using an old computer, there’s a possibility that you already encountered this error message during bootup; “CMOS checksum error – Defaults loaded”. At this point, the PC will halt its operation and requires you to press F1 to continue or DEL to enter setup (mostly but also depends on motherboard) to proceed.
This is caused by incorrect or corrupted CMOS values. BIOS settings are stored in CMOS. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, the error message will be displayed.
For most cases, this is caused by the motherboard battery. Buy a new one to any electronic retailers in your area and replace it. Turn on your computer and press the stated key to enter the BIOS setup. It can be DEL for some or F2 but this depends on your computer. On the BIOS menu, try to change the DATE and TIME settings because their values are reset to different value. Most settings are set to default so leave it as it is. Save the settings and reboot your computer.
Oct 04, 2008 | MSI PM8M-V Motherboard
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5kpl Se Motherboard Intel G31 Lga 775 Logo
1,350 people viewed this question
Top ASUS Audio Players & Recorders Experts
ALI DEHBAN
ALI DEHBAN
Level 1 Expert
David Payne
David Payne
 Grubhead
Grubhead
Are you an ASUS Audio Player and Recorder Expert? Answer questions, earn points and help others
