Question about Husqvarna 295cc Back Pack Blower HVH 130BT
New; ran 4-5 hrs; then quit. now no spark. - Husqvarna 295cc Back Pack Blower HVH 130BT
  • 64 Answers
Check the spark! Could be the ignition shuts down when the engine runs too hot. You could use a little more oil mix.
Posted on Nov 09, 2012
John deere 2032 will not start after rolled on its side, battery is fully charge, will not crank
You may need to remove the glow plugs and then crank starter to remove any fuel/oil from the cylinders! but stand back as it will spray whatever is in the cylinders out at quite a rate, covering the area around the glow plug holes with rags will catch most of the ejected oil/fuel
Sep 08, 2017 | John Deere Garden
Lay-Z-Spa e01 error
E01 error code. Drained hot tub, unhooked green egg. Ran hose into the two filter pipes and back flushed the pump. Plugged back in and it works fine now.
Jun 02, 2017 | Pool & Spa
How do you fix the idle on a 1990 isuzu trooper 4 cylinder, and where is the adjustment?
The idle screw is on the throttle body near where the gas pedal cable attaches to it. Not sure what sensors it has and less familiar with pre 90's cars but if it has an IAC or TPS could be causing problems. Clean the throttle body/carb.
Sep 05, 2010 | 1987 Isuzu Trooper
Brand new GE modelGLD4408RWW, runs for avery long time on the normal cycle (3 or 4 hrs.). Did not even flush the detergent out of the cup on the light wash, which ran for about an hour and 30 minutes. The...
is the water hot enough prime the sink first then start the dish washer/make sure its hooked to hot water i know it sounds dumb but i have ran across that
May 14, 2010 | Dishwashers
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Drove my1989 5.0 litre truck 60 miles to my cottage. It ran great
i would check your throttle position sensor first
Mar 20, 2009 | 1989 GMC C1500
Troubleshooting
8 flashes indicates a main processing IC on the video process board has failed You will need to have the BU board replaced.
Jul 27, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Husqvarna 295cc Back Pack Blower HVH 130BT Logo
109 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
