Question about Microwave Ovens
Kenmore Microwave Model #401.80099700 Touch Pad Not working
Hi, Yesterday all of a sudden some of the touch keypads on my microwave stopped working. I can not even use the clear button. I can put in for example 3 minutes etc. but I have to use all that time before I can enter another time as I can not clear it. It seems only buttons I can use are numbers on high and start, no defrost etc. I am hoping there is just a circuit board that can be replaced easily. Any help would be greatly appreciated!! Thanks
  • kris perkins Nov 09, 2012
    Thanks for the help. I tried shutting the door hard and it didnt help..The number pads still work, some other buttons work off and on. Tonight when I was just pushing the buttons defrost worked...There was no fuse blown ever or replaced. Nothing out of the ordinary to trigger anything..
SOURCE: samsung microwave oven (touch panel problem)
you can use the express button in touch pad,
Posted on Jan 20, 2008
sharcnet
  • 2130 Answers
SOURCE: My Touch pad does not work, can someone help?
It sounds like the keypad is worn out. The fact that you can get them to work sometimes by what direction you push on them, tells me that the contacts are not working correctly.
Did you have this problem prior to the fuse blowing or did it start after you replaced the fuse?
I don't believe the fuse blowing is related to the keypad problem. I also don't believe that you have a microprocessor problem because you say that the function buttons work but the number keys don't work right. If the microprocessor was faulty, it would not be able to read any of the keys.
The fact that the number keys are not working doesn't surprise me. When you go to cook something, you will press the number keys several times, while only pressing start or stop once. This is why your number keys have worn out first. These keys have a limited number of cycles (presses) and it sounds like its time for a new keypad.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Posted on Feb 21, 2008
Illeagle
  • 525 Answers
SOURCE: Panasonic microwave start button
You may have a sticky door switch. Try a simple "slamming" of the door, don't over do it, just a little harder than normal. This may help pop the plunger in the switch back up. The switch could have also become loose and moved out of its adjustment.
If this does not help, a technician should save you time and money with this sometimes perplexing problem.
Posted on May 24, 2008
SOURCE: kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Posted on Aug 16, 2008
SOURCE: My Galanz microwave WP800AP20-6 is beeping for no reason
I have similar problem
Posted on Jul 27, 2010
My start button of microwave suddenly stopped working only its stop button works.What can I do?
You could have a defective door switch. Or, a bad membrane switch on the touch pad. Or, the ribbon cable (if so equipped) between the touch pad and circuit board might not be making connections on all of its wires.
Sep 14, 2016 | Microwave Ovens
Kenmore microwave 721 keypad buttons does not work.
The key pad or the system Bord is faulty. You have replace the keypad unit first.
If you wish to get any more detailsthen check the bellow added link.
www.electro-medical.blogspot.com
Jun 29, 2016 | Kenmore Microwave Ovens
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
Kenmore oven-microwave 911 41479791 I get E 01 error.
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore 63662 / 63664 / 63669 Microwave...
My Touch pad does not work, can someone help? My touch pad doesn't work. If I unplug the microwave and plug it again, it will show an error message but it will work one time only and then the pad will not...
What error message is it showing? What is your model?
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 30, 2008 | GE PVM2070SMSS Microwave Oven
Kenmore elite microwave touch screen stopped working
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Kenmore microwave
The Keypad is a Circuit.Each of the Function Buttons is a switch. The same "Touch" Techinology as is used of your TV Remote Control Pad or your Telephone. It would appear that your Keypad Circuit is Open, not allowing touch commands to reach the Control Board.The Keypad will have to be replaced. Best done by a Professional. I have seen "Rare" cases of a defective Door Switch causing such symptoms.
Jan 26, 2008 | Microwave Ovens
Microwave Ovens Logo
79 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
