E machines keeps starting up and shutting down.
E machines keeps starting up and after it loads it shuts down.
  • jpbello Jan 05, 2009
    Thank you, I will give it a go!
    Problem Solver:
  • 5 Answers
Hello you might have a virus or memory leak.the best easiest way is to reload the windows and if it happens again then you know its memory.
Posted on Jan 05, 2009
GE WPRE6150 -Shuts down
4 flashes = Overfill fault presure pipe blocked
Check for high water pressure to unit, usually an indication of a bad water inlet valve.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | GE Profile WPRE6100G Top Load Washer
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
My washing machine keeps shutting down and blowing a fuse.
You must have a short circuit ,try disconnecting things start with the heater element, disconnect one wire see if it still blows...next try motor plug, until the fault clears at least this tells you what the problem part is.....
Apr 11, 2010 | LG WM-2077C Front Load Washer
My laptop will not load at all i boot up the fan will go on then the laptop shuts down reboots shut down reboot shut down and will not load anything just keeps rebooting how can i fix this with out losing...
press F8 immedialty after switcing on...try to load the option "Load last good system that worked b.....etc etc" else...
shut down restart press F8 select Safe Mode...
if it starts in Safe mode and u can get to Desktop...
get Tuneup Utiltiy from my website
www.sureshayyar.110mb.com
clean ur registry and try to start in normal mode...
Jan 04, 2010 | Acer Aspire 5520-5908 Notebook
My washer is saying F dL when I try to start a load
can you manage to lock +unlock door buy shutting off machine and starting over .does it run for a while then shut down / if you shut of machine will door unlock .if so ccu board could be problem
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
The loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
May 02, 2009 | Apple MacBook Air
Fisher & Paykel top load intermittent running
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Dec 06, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing machine - door problem
it sounds like door mechanisim has fallen off.remove the top of washer/dryer and look down the front to where the door catch shuts and see if there is anything attached to it.if not your have to reconnect it.Let me know and ill give ya more details
Sep 03, 2007 | Hotpoint Ultima WD72 Front Load...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
