Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Error code c3100 taskalfa 180
Error code 3100
How do i with the call service 3100
C3100 is a scanner carriage problem... The error code indicates that the "home signal" is not reaching the main board in the required time;if its new machine check the scanner lock removed or not.other wise open platen glass and clean all optics,,if its not working check the main board,&connector cables,,,,
Nov 18, 2014 | Kyocera Mita TASKalfa 180 Black Toner...
Code erreure c3100 pour taskalfa 180
Scanner carriage error
The home position is not correct when the power is turned on, at the end of a reading process of the table and document processor.
May 13, 2014 | Kyocera Office Equipment & Supplies
My new kyocera taskalfa 181 copier diplay call service c3100
please unlock the 2 scanner lock on top left side of the machine. the lock will be in yellow colour and it will covered by red tape.
Sep 20, 2012 | Copystar Kyocera Taskalfa 181 Copier
How do i solve error c3100 in brand new TASKalfa 180
You need to update the machine firmware, it will takecare of this Error.
Nov 08, 2011 | Kyocera TASKalfa 180 Copier
Copier Taskalfa giving me Error code C3100
clean the optics for dust .it is related to the scanner and 90% is because of the dirty optics.clean it well
Jul 25, 2011 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Am getting an error code C3100.
check if the scanner cables in the scanning section are out of position if not clean the mirrors and the scanner lamp.
Dec 22, 2010 | Kyocera TASKalfa 180 Copier
Installing a new kyocera TASKalfa 250ci and i got the error error c3100
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Dec 22, 2010 | Kyocera Office Equipment & Supplies
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
